water and oil pump
06-09-2007, 03:02 AM
water and oil pump
buying all the parts to rebuild my engine at the minute,
but having trouble finding water and oil pump for the AE86
is the water and oil pumps for the RWD mounted engine differant from the oens used in the FWD corollas and the MR2 as i can find them easy enough just not the AE86 ones lol
cheers
[Image: AEU86 AE86 - water and oil pump]
DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS
06-09-2007, 04:13 AM
water and oil pump
As far as I know the oil pumps are the same on all 16 valve 4AGE's.
FWD and RWD water pumps will interchange, but RWD pumps have a
stronger nose to support the weight of a fan. If you have an electric
fan you can use the FWD pump; just don't expect a FWD pump to last
for long if you bolt a fan to it Tongue
Cheers... jondee86
06-09-2007, 09:05 PM
water and oil pump
The FWD pump is a bit shorter than the RWD one, I bought one a long while back and when I installed it I noticed it was the wrong type (by which time it was too late to return it). You can use the FWD pump, but you'll need to use the fwd pulley, since that put's the position of the belt in the same place as the stock pump&pulley combination.
For the record, I've been driving with this pump for about a year now, it has held up fine, but I dont rev the engine high all the time. The RWD pump is probably longer due to a bigger bearing to spread the load of the fan a bit.
06-09-2007, 09:36 PM
water and oil pump
cheers guys
i got the waterpump easy enough
it is the oil pump i am trying to get now
thewater pump would have been fine as i have switched to electric fans now Big Grin
12-01-2011, 11:42 PM
water and oil pump
I am also rebuilding engine and I am looking for oil pump. I found one on ebay:
http://www.ebay.com/itm/81-95-Toyota-Geo...33694bb213
I also red that there are aisin copies wtih aisin printed on the pump. I would need advice where to get some oem quality oil pump
Thanks
12-01-2011, 11:44 PM
water and oil pump
Here they sell the oil pump
1.6 GT Coupe, AE86, 05/85 > 12/87
http://www.fensport.co.uk/Parts/Model_4/...ry_12/1072
£117.35 Inc VAT
iThat should be the rwd pump and they are from uk it seems.
12-02-2011, 12:13 AM
water and oil pump
What´s wrong with your old one? It´s not like they break very often specially not around the 150000km mark.
I disassembled my genuine oilpump wich has done at least 300k and there was nothing to worry about...
If you´re worried, check the relief valve + spring, that the only part in there that can fail.
The pump is by far the best lubicated part in your engine. Big Grin
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
12-02-2011, 02:49 AM
water and oil pump
ditn Wrote:Here they sell the oil pump
£117.35 Inc VAT
Thanks for the link
12-02-2011, 02:59 AM
water and oil pump
fax0815 Wrote:What´s wrong with your old one? It´s not like they break very often specially not around the 150000km mark.
It doesnt seem wrong but oil pump failure can be critical so I thought that if I spend something about lets say 500 euro on the engine I would be pissed if something happens. And I think that new pump will make higher oil pressure and flow which is better for engine. Next thing is that you never know(if someone knows how long will toyota keep making parts for 4age let me know ) when toyota will stop producing parts for 4age.
But thanks I will consider your advice and check the old one first. I wont throw the old one away...
12-07-2011, 04:32 AM
water and oil pump
Get a smallport pump. Better design, as it is less prone to cracking under sustained high-rpm use and higher flow/volume.
Smallport & 20v (silver & blacktop) use the same upgraded gear.
Andrew
  20v BT - which oil pump? Mylesmck 4 2,799 06-21-2022 04:51 PM
Last Post: pack
  Fuel pump issue DJexor 11 5,149 04-29-2022 05:45 AM
  Water Temperature Instrument not moving - Sender Gauge Hama86 8 7,567 12-06-2017 06:48 PM
  fuel line hose from the pump Wikizz 4 6,055 10-16-2017 07:11 PM
Last Post: jdm86gtz
  20v conversion water relocation izanagi 1 5,442 06-15-2016 09:45 AM
