will the 0.5 mm HEADGASKET clear?
01-23-2008, 01:27 PM
Hi,
do the valves interfere with pistons when the 0.5 mm headgasket is used? (in case of belt snaping)? -stock bluetop 4ag
01-23-2008, 03:01 PM
They dont interfere when working, if the belt breaks, i dont know...
[Image: AEU86 AE86 - will the 0.5 mm HEADGASKET clear?]
Cump´s
Filipe Oliveira
01-23-2008, 04:58 PM
i mean when the piston is in top dead position and the valves at full lift. will it clear? a non interferance engine is a good insurace. just in case..
01-23-2008, 05:48 PM
Even with the stock gasket they will interfere in such case.Just to make you feel better, there is a tiny chance (i would say there's no chance but you never know Tongue ) for the valves to remain opened if the belt fails...Keep in mind that there are valve springs and camshaft inertia that play role in the above equation!
JapanPower
UoP Racing website
UoP Racing videos
01-23-2008, 06:59 PM
with the standard engine, even if the belt brakes valves don't touch pistons, it's a non interference engine. with a small head gasket i don't know.
It's easy to try though !!
install the head gasket , put the piston one in TDC and rotate both camshaft's independently, if they do 1 full turn both without touching anything u are still ok ( i would say that with the 0.8 gasket it's still ok , but with the 0.5 it might start to be an interference engine ( like 90% of the other engines on our roads))
01-23-2008, 07:33 PM
yeah i want to know before i actually buy such a headgasket.
01-23-2008, 09:30 PM
it wouldnt be a matter to me.
Just go for it. Put a new timing belt, it will last forever!
Cump´s
Filipe Oliveira
01-23-2008, 09:59 PM
Lipinhu Wrote:it wouldnt be a matter to me.
Thumbs up! interference or non-interference - every good engine needs good timing belt
84' AE86 Levin
96' 500HP WRX, powered by landikar
01-24-2008, 01:41 PM
Apolan Wrote:i mean when the piston is in top dead position and the valves at full lift. will it clear? a non interferance engine is a good insurace. just in case..
Found this on web (by billzilla)
Quote:"You dummy-assemble the engine, (just one cylinder will do) with plasticine on the piston tops and lightly cover the top of the plasticine with oil so the valves don't stick.
Then turn the engine over slowly by hand, then pull it apart again. Section the plasticine to see how far the valves have pushed into it. You typically need a good 0.060" or 1.5mm to be sure it'll all clear okay."
http://www.toymods.net/forums/showthread...694&page=2
01-24-2008, 02:18 PM
I have wiseco pistons, decked the head 0,60mm, decked the block 0,1mm, have a 0,8mm head gasket and TODA 288/7.9mm camshafts. There's interference on the intake side only.
I would say, almost sure of it, that if you install a 0,5mm head gasket with the head at stock trim, you will still have a non interference 4A-GE.
Best regards
  Clear Lenses SniperGT 85 82,742 12-16-2012 09:28 PM
Last Post: Aram
  Silvertop Headgasket? byd1380 3 4,067 01-05-2009 06:02 PM
Last Post: byd1380
  head skiming/size headgasket/hks f-con! nick 9 8,337 04-10-2008 06:17 PM
  about 5mm TRD headgasket filh 24 18,393 04-13-2007 08:25 PM
Last Post: jamiemirror
  5mm headgasket filh 14 11,199 01-28-2007 08:29 AM
Last Post: Plex
