16V to 20V Blacktop (help!)
09-14-2007, 11:39 AM
Thanks for your support jondee86! :wink:
You also have a 20V blacktop in your 86?
86'LEVIN Track Project
09-14-2007, 12:35 PM
Nao... not the 20 valve blacktop. I have the 16 valve smallport
installed. For the moment it is completely standard except for some
weight removed from the flywheel.
Just now I am completing a rebuild of the rear axle and suspension
(brakes, TRD bushings, new bearings, shocks and springs). Next will
be the front suspension, and then I have some engine modifications
planned Smile
Cheers... jondee86
09-18-2007, 11:49 AM
jondee86 Wrote:FWD engine does not have a spigot bearing fitted. It is just a standard
2RS bearing available for a few dollars from any bearing shop. You will
need to measure the inside and outside diameter, as I don't have a note
of the size. Otherwise buy it from an auto parts store. Tap it into the end
of the crankshaft until it stops moving.
Cheers... jondee86
NSK K01 6001V
DXdXl (diam.external, diam.internal, thickness)
28X12X8 mm
sealed
09-19-2007, 11:37 PM
NSK K01 6001V
28X12X8 mm
sealed
That´s the reference of the bearing right? Thanks a lot jamiemirror! Thumbs up!
About the exhaust, is it a good idea to use the 16V headers with the 20V? I know that they will not fit, but I think that can be fixed
What do you guys think?
09-20-2007, 09:24 AM
Check this link too:
http://www.phuckdrifting.com/20Vinstall.html
You can use the 16V header but some small adjustments will have to be made. You will have to cut some material from one of the mount holes.
You will see all this in the link.
:wink: Thumbs up! Wave
Speed Industries
Hurdnerwaeldlistr. 73
8808 Pfaeffikon
Switzerland
e-mail: [email protected]
phone: +4155 420 15 69
page: http://www.speed-industries.ch
MSN: [email protected]
We have all the parts your Hachi needs
09-20-2007, 09:55 AM
86Pilot Wrote:NSK K01 6001V
28X12X8 mm
sealed
Yes, pilot bearing dimensions :-)
I think that OBX headers from Ebay were actualy designed for 20V engine.
09-21-2007, 04:34 PM
speed-inc Wrote:Check this link too:
Does anyone know what waterline relocation kit he used here?
  Refreshed 20v blacktop first start.. Mylesmck 6 757 10-07-2024 07:55 AM
  20v Blacktop conversion.... Mylesmck 0 479 04-29-2024 05:48 PM
Last Post: Mylesmck
  Improve 20V Blacktop cooling pack 0 985 06-07-2023 01:18 PM
Last Post: pack
  Shims 20V Blacktop CHOPKIN2 3 4,747 12-23-2017 11:07 PM
  stock injector deadtime for 4age 20v silvertop/blacktop injector ditn 1 5,882 02-20-2016 11:48 AM
