16V to 20V Blacktop (help!)
09-14-2007, 11:39 AM
Thanks for your support jondee86! :wink:
You also have a 20V blacktop in your 86? 86'LEVIN Track Project |
09-14-2007, 12:35 PM
Nao... not the 20 valve blacktop. I have the 16 valve smallport
installed. For the moment it is completely standard except for some weight removed from the flywheel. Just now I am completing a rebuild of the rear axle and suspension (brakes, TRD bushings, new bearings, shocks and springs). Next will be the front suspension, and then I have some engine modifications planned Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
09-18-2007, 11:49 AM
jondee86 Wrote:FWD engine does not have a spigot bearing fitted. It is just a standard NSK K01 6001V DXdXl (diam.external, diam.internal, thickness) 28X12X8 mm sealed |
09-19-2007, 11:37 PM
NSK K01 6001V
DXdXl (diam.external, diam.internal, thickness) 28X12X8 mm sealed That´s the reference of the bearing right? Thanks a lot jamiemirror! About the exhaust, is it a good idea to use the 16V headers with the 20V? I know that they will not fit, but I think that can be fixed What do you guys think? 86'LEVIN Track Project |
09-20-2007, 09:24 AM
Check this link too:
http://www.phuckdrifting.com/20Vinstall.html You can use the 16V header but some small adjustments will have to be made. You will have to cut some material from one of the mount holes. You will see all this in the link. :wink: Speed Industries Hurdnerwaeldlistr. 73 8808 Pfaeffikon Switzerland e-mail: [email protected] phone: +4155 420 15 69 page: http://www.speed-industries.ch MSN: [email protected] We have all the parts your Hachi needs |
09-20-2007, 09:55 AM
86Pilot Wrote:NSK K01 6001V Yes, pilot bearing dimensions :-) I think that OBX headers from Ebay were actualy designed for 20V engine. |
09-21-2007, 04:34 PM
speed-inc Wrote:Check this link too: Does anyone know what waterline relocation kit he used here? |
Refreshed 20v blacktop first start.. | Mylesmck | 6 | 756 |
20v Blacktop conversion.... | Mylesmck | 0 | 477 |
04-29-2024 05:48 PM Last Post: Mylesmck |
Improve 20V Blacktop cooling | pack | 0 | 982 |
06-07-2023 01:18 PM Last Post: pack |
Shims 20V Blacktop | CHOPKIN2 | 3 | 4,747 |
12-23-2017 11:07 PM Last Post: oldeskewltoy |
stock injector deadtime for 4age 20v silvertop/blacktop injector | ditn | 1 | 5,882 |
02-20-2016 11:48 AM Last Post: Bean |
