20V Water setup route
01-01-2011, 11:13 PM
I have painted (badly) a sketch of how I would direct the water passages thru my engine. Is this a good way? Dooable?
Happy new year
Don´t Think About The Past,
Live In The Present And
Dream About Tomorrow
01-02-2011, 02:49 PM
yes that's correct but you didn't include your heater flow control tap.
Did you read my guide?
want some parts for that?
My website:
S-86.com
01-09-2011, 11:23 AM
Hi thanks.. Yes I have read your homepage many times.. Bad thing is that i dont really have the cash to buy your stuff right now :/
Just thinking about the cheapest but solid way. ^_^
what exactly is the heater flow control tap?
thanks again
01-09-2011, 12:05 PM
well I hope to be in buisness for many years yet so you can take your time.
If you want to use your original 20v pump them my basic water outlet and a common extenal thermostat can be used.
The heater flow cotrol tap is the valve that is bolted to the firewall near the clutch master on the firewall. Here it's as pictured in my engine bay at the end of my airbox. It's the brass colour thing that has the wiring harness go over the top and has the hoses go to it.
[Image: AEU86 AE86 - 20V Water setup route]
As the name suggests it turns the water flow on and off for the heater core so that when it's in the fan only position there is no hot water flowing through the core making the air hot.
My website:
S-86.com
01-09-2011, 03:01 PM
Then I know what ya mean.. I know my pic is not accurate but it is included in it hhaha.. only way for water to pass thru the radiator is thru those ports.. right ? ^_^
01-11-2011, 12:29 AM
not sure what you mean by that. Your diagram is right bar needing to add this valve beween the back or the top outlet of the engine to the heater core.
My website:
S-86.com
  Water Temperature Instrument not moving - Sender Gauge Hama86 8 8,088 12-06-2017 06:48 PM
  20v conversion water relocation izanagi 1 5,682 06-15-2016 09:45 AM
  4 Link setup and Traction brackets Jezza_hr 5 10,650 07-21-2014 09:12 PM
  20v with 16v Water Relocation Kit D.O 9 16,493 06-12-2014 02:48 AM
Last Post: jondee86
  Machining Pistons to run 20v head... And FCR's on a 20v? PazzaAE86 2 5,294 09-15-2013 01:08 AM
Last Post: jondee86
