4AGE 20v turbo upgrade
05-02-2011, 05:55 AM
Hi, I was just wondering how much power you guys think will this setup pull out in my AE86 with a 4AGE 20v Silvertop engine. Yeah its a long list and I spent allot
![]() ![]() So here it goes: Turbo: Garret T3/ T4 ball bearing Turbo. [list] [*]Microtech LT10s ECU [*]New complete 20valve gasket kit; [*]ARIAS low comp. pistons 8.9:1 C.R.; [*]4AGZE supercharger connecting rods; [*]ACL Race bearings with thrust washers; [*]Balanced and polished crank; [*]Cometic head gasket; [*]ARP Main Studs. [*]ARP Head studs; [*]TOGA High Volume Oil Pump; [*]3SGTE 440cc injectors; [*]New original timing belt; [*]3 point racing clutch; [*]Custom made air intake manifold; [*]Custom made exhaust manifold. [*]Denso Fuel Pump 950-0155 280Lph; [*]CXRacing Aluminum Radiator; [*]2.5” intercooler tubing with hoses and clamps; [*]25x12x3 Intercooler; [*]HKS Universal SSQV3 BOV; [*]Tial 38mm wastegate; [*]Manual Boost Controller; [/list:u] Any other recommendations would be highly appreciated. |
05-02-2011, 06:15 AM
No cams while doing the motor?
HP capability will depend on your turbo specs and fuel and boost levels. I think if you turbo is capable your injectors will be too small. If you ran a decent sized turbo, and injectors were big enough, you should be looking at circa 350-400WHP. A mate has a cam'd up 16v with a GT30 turbo, and he makes 550WHP on his. |
05-02-2011, 06:18 AM
Oh and recommendations...
Go to a GT series turbo, maybe a GT30 or 28 with a .48 or .63 A/R (depending on your spool requirements and power goals). Go get some 600cc+ injectors, and get a decent ECU! The new Link G4's are awesome and well priced. Maybe some Kelford cams ![]() All on the basis you are chasing decent numbers... maybe get a blacktop head too. |
05-02-2011, 06:47 AM
4000GT Wrote:Oh and recommendations... Thanks for the reply 4000GT. I'm planning to drift with this car, and a quick spool would be nice. Not yet on planning to change the cams. What duration and lift you recommend for the cams? |
05-02-2011, 07:01 AM
Ah well, a drift car, you dont need enormous amounts of power, basically as long as you get a good tune in with good fuel, you will get all the power you need, maybe 300WHP depending on your current turbo specs.
Im running a Kelford cam, 288 degree duration and 10mm of lift. |
05-02-2011, 07:12 AM
Niiice thanks for the info and recommendations man. Hope this post could help others also. cheers
05-09-2011, 11:26 PM
Hey any of you know what is the best clutch for this motor with a T50 tranny?
whats the crack with 16v turbo? | kazi | 5 | 6,544 |
08-02-2017 12:15 AM Last Post: kazi |
Radiator oem or upgrade on racecar? | Jimmi The Kid | 5 | 6,063 |
06-23-2017 05:21 PM Last Post: pack |
Bluetop on turbo | leon205gti | 7 | 8,277 |
09-20-2016 09:17 PM Last Post: leon205gti |
Ta60 carina steering upgrade? | Allexz | 15 | 16,142 |
06-01-2016 08:12 AM Last Post: Allexz |
can i just slam a oem turbo on it ? | MC_JP | 3 | 6,253 |
12-17-2014 11:04 PM Last Post: oldeskewltoy |
