4AGE 20v turbo upgrade
05-02-2011, 05:55 AM
Hi, I was just wondering how much power you guys think will this setup pull out in my AE86 with a 4AGE 20v Silvertop engine. Yeah its a long list and I spent allot Tongue Confused.
So here it goes:
Turbo: Garret T3/ T4 ball bearing Turbo.
[list]
[*]Microtech LT10s ECU
[*]New complete 20valve gasket kit;
[*]ARIAS low comp. pistons 8.9:1 C.R.;
[*]4AGZE supercharger connecting rods;
[*]ACL Race bearings with thrust washers;
[*]Balanced and polished crank;
[*]Cometic head gasket;
[*]ARP Main Studs.
[*]ARP Head studs;
[*]TOGA High Volume Oil Pump;
[*]3SGTE 440cc injectors;
[*]New original timing belt;
[*]3 point racing clutch;
[*]Custom made air intake manifold;
[*]Custom made exhaust manifold.
[*]Denso Fuel Pump 950-0155 280Lph;
[*]CXRacing Aluminum Radiator;
[*]2.5” intercooler tubing with hoses and clamps;
[*]25x12x3 Intercooler;
[*]HKS Universal SSQV3 BOV;
[*]Tial 38mm wastegate;
[*]Manual Boost Controller;
[/list:u]
Any other recommendations would be highly appreciated.
05-02-2011, 06:15 AM
No cams while doing the motor?
HP capability will depend on your turbo specs and fuel and boost levels. I think if you turbo is capable your injectors will be too small. If you ran a decent sized turbo, and injectors were big enough, you should be looking at circa 350-400WHP.
A mate has a cam'd up 16v with a GT30 turbo, and he makes 550WHP on his.
05-02-2011, 06:18 AM
Oh and recommendations...
Go to a GT series turbo, maybe a GT30 or 28 with a .48 or .63 A/R (depending on your spool requirements and power goals). Go get some 600cc+ injectors, and get a decent ECU! The new Link G4's are awesome and well priced. Maybe some Kelford cams Smile
All on the basis you are chasing decent numbers... maybe get a blacktop head too.
05-02-2011, 06:47 AM
4000GT Wrote:Oh and recommendations...
Thanks for the reply 4000GT. I'm planning to drift with this car, and a quick spool would be nice. Not yet on planning to change the cams.
What duration and lift you recommend for the cams?
05-02-2011, 07:01 AM
Ah well, a drift car, you dont need enormous amounts of power, basically as long as you get a good tune in with good fuel, you will get all the power you need, maybe 300WHP depending on your current turbo specs.
Im running a Kelford cam, 288 degree duration and 10mm of lift.
05-02-2011, 07:12 AM
Niiice thanks for the info and recommendations man. Hope this post could help others also. cheers Thumbs up!
05-09-2011, 11:26 PM
Hey any of you know what is the best clutch for this motor with a T50 tranny?
  whats the crack with 16v turbo? kazi 5 6,557 08-02-2017 12:15 AM
Last Post: kazi
  Radiator oem or upgrade on racecar? Jimmi The Kid 5 6,074 06-23-2017 05:21 PM
Last Post: pack
  Bluetop on turbo leon205gti 7 8,298 09-20-2016 09:17 PM
Last Post: leon205gti
  Ta60 carina steering upgrade? Allexz 15 16,205 06-01-2016 08:12 AM
Last Post: Allexz
  can i just slam a oem turbo on it ? MC_JP 3 6,261 12-17-2014 11:04 PM
Last Post: oldeskewltoy
User(s) browsing this thread:
