4age distributor, what's similiar ?
11-08-2010, 05:21 PM
Hi
I need few parts from 4AGE distributor, but i'm unwilling to sacrifice working unit.
Does anybody know, is there any distributor which is similar.
I need gear at the and, shaft, and mounting bracket:
[Image: AEU86 AE86 - 4age distributor, what's similiar ?]
Thanks
11-11-2010, 12:41 PM
3A carb dizzys, with built in igniter, will fit, possibly with a bit of machining to shorten the shaft.
You'll need the worm gear on the end, and possibly the bitch pin.
http://ja.wikipedia.org/wiki/%E3%83%95%E...B:3-AC.jpg
11-11-2010, 01:25 PM
Great, thanks.
I did little searchup (probably should've done it first Smile) and many dizzys from 70's and begining of 80's look the same, seem like it was standard design and 4AGE was last to get gear/shaft. Newer use different design.
Next stop, salvages, to compare 4AGE dizzy with Tercels, Starlet's and similar.
  16v distributor hole plug harkes 8 11,358 10-12-2016 11:13 AM
Last Post: harkes
  Changing distributor when carb 4age izanagi 14 19,196 07-04-2016 03:27 PM
Last Post: Uzelac
  Distributor position and cranking pack 13 22,759 07-01-2013 11:08 PM
Last Post: pack
  weak spark. new distributor? please help. stasis_dc5 3 8,366 04-11-2011 12:35 AM
Last Post: fax0815
  distributor prob alex-evo 7 8,784 12-16-2010 12:33 AM
Last Post: alex-evo
