4age distributor, what's similiar ?
11-08-2010, 05:21 PM
Hi
I need few parts from 4AGE distributor, but i'm unwilling to sacrifice working unit. Does anybody know, is there any distributor which is similar. I need gear at the and, shaft, and mounting bracket: ![]() Thanks |
11-11-2010, 12:41 PM
3A carb dizzys, with built in igniter, will fit, possibly with a bit of machining to shorten the shaft.
You'll need the worm gear on the end, and possibly the bitch pin. http://ja.wikipedia.org/wiki/%E3%83%95%E...B:3-AC.jpg http://www.skynet.ie/~eireae86 |
11-11-2010, 01:25 PM
Great, thanks.
I did little searchup (probably should've done it first ![]() Next stop, salvages, to compare 4AGE dizzy with Tercels, Starlet's and similar. |
16v distributor hole plug | harkes | 8 | 9,704 |
Changing distributor when carb 4age | izanagi | 14 | 15,864 |
Distributor position and cranking | pack | 13 | 19,688 |
07-01-2013 11:08 PM Last Post: pack |
weak spark. new distributor? please help. | stasis_dc5 | 3 | 7,315 |
04-11-2011 12:35 AM Last Post: fax0815 |
distributor prob | alex-evo | 7 | 7,466 |
12-16-2010 12:33 AM Last Post: alex-evo |
