5mm headgasket
01-24-2007, 03:50 PM
5mm headgasket
Do you have to change anything else when putting a .5mm headgasket? And how much would that raise the cr, compared to the stock 1.2 (i think)
01-25-2007, 12:31 PM
5mm headgasket
for sure , it's a 5mm TRD : parts n° : 11115-AE824
filh Filh Save the RWD cars |
01-25-2007, 12:33 PM
5mm headgasket | |||
01-28-2007, 08:29 AM
5mm headgasket
be sure to re-tighten those headstuds before you start up the motor... the stock bolts are 'torque to yield' meaning they stretch a little bit after installation... I usually wait an hour or so and re-check the TQ on them....
"Sometimes giving up isn't the answer we're looking for, but its the only answer we have" |
Silvertop Headgasket? | byd1380 | 3 | 4,163 |
01-05-2009 06:02 PM Last Post: byd1380 |
9.5mm lift camshafts with OEM followers... anyone? | apardal | 9 | 9,320 |
10-15-2008 03:24 PM Last Post: robokill |
head skiming/size headgasket/hks f-con! | nick | 9 | 8,573 |
04-10-2008 06:17 PM Last Post: oldeskewltoy |
will the 0.5 mm HEADGASKET clear? | Apolan | 15 | 13,493 |
01-31-2008 01:48 PM Last Post: meshin |
about 5mm TRD headgasket | filh | 24 | 19,111 |
04-13-2007 08:25 PM Last Post: jamiemirror |
