7AGE - How i did it!
04-08-2005, 06:32 PM
What cc are the brown injectors ? Is there a cross reference for this ?
04-08-2005, 06:53 PM
TOYOTA INJECTORS
(NIPPON DENSO) TEST CC / MIN COLOR OHMS lbs/HR kPa APPLICATION 430 black 2.9 42.2 255 7MGTE, 3SGTE 365 red/orange 2.9 33.9 255 4AGZE 295 pink 1.6 28.9 255 22RTE 295 yellow 2.7 28.9 255 7MGE 210 blue 2.4 20.6 255 4AGE 200 dark grey 1.7 19.6 290 3SFE 200 beige 1.7 19.6 290 4YE 200 orange 1.7 19.6 290 22RE 200 brown 1.7 19.6 290 3VZE 200 pink 2.7 19.6 290 4AGE 182 dark grey 2.0 17.8 255 4AGE 182 grey 2.4 17.8 255 4ME,5ME, 5MGE 145 light green 2.4 14.2 255 1GE, 4K 550 purple 13.8 53.9 290 2JZGTE US 430 white 13.8 42.2 255 2JZGTE JAP 315 pink 13.8 30.9 290 3SGE 315 light green 13.8 30.9 290 7MGE 295 green 13.8 28.9 255 3SGE 282 light green 13.8 27.6 290 2RZE 282 purple 13.8 27.6 290 2TZFE 250 purple 13.8 24.5 290 1UZFE 250 green 13.8 24.5 290 4AGE 250 purple 13.8 24.5 290 4AGE 250 brown 13.8 24.5 255 3SGE 250 yellow/orange 17.0 24.5 255 22RTE 213 light blue 13.8 20.9 290 3FE 213 beige 13.8 20.9 290 4AGE 213 yellow 13.8 20.9 290 5SFE 200 dark blue 13.8 19.6 290 3SFE 200 orange 13.8 19.6 290 22RE 200 blue 13.8 19.6 290 22RE 200 brown 13.8 19.6 290 3VZFE 200 red 13.8 19.6 290 2VZFE 176 light green 13.8 17.3 290 4AFE 176 grey 13.8 17.3 290 4AFE 155 red 13.8 15.2 288 3EE 155 dark blue 13.8 15.2 289 3EE 155 violet 13.8 15.2 290 3EE, 2EE 155 light blue 13.8 15.2 290 1GFE 155 violet 13.8 15.2 290 4AFE here you go jon - sorry table didnt coppy that well (you might want to check it out on toysport.com in the tech section) jon, if you do want to come check it out i will definatly buy those TRD top mounts off you! ps just had car CO tested and when hot it leans out in the top end so an uprated fuel pump is required i am going to fit a surge tank etc because i do occasionally get fuel starvation when drifting Run Free and take a Goodline V8FOURCAM32 MK3 Supra Patchwork AE86 from 4AGE to 7AGE to 4AGZE and now 4AGEU20v suzuki cappuccino mondeo TD |
04-08-2005, 10:39 PM
I'll try to make it a how-to soon.
04-08-2005, 11:59 PM
I have a S-AFC coming to handle a bit more fuel if i ever get the hks cams into an engine.
thanks for the info, i had found a set of 235 pink injectors, but i guess there is not quite enough fuel there. |
04-09-2005, 12:46 AM
Hey Jon do you know what exactly the TRD fuel controller does (is it good?) and how can it be connected to the ECU?
AE86 FANATIC!!! |
04-09-2005, 11:09 AM
I getting one of the older ones with the dials rather than the poser blue one. It allows me to boost fuel quantaties upto + 30% at certain rev ranges. I guess that ultimately the fule pressure will not be enough or the injectors too small, but i'm only looking for upto 150bhp anyway, not interested in getting an aftermarket ecu [too expensive]. It just piggy backs onto the standard ecu, you can download an english instrution manual from the web for it. The S-AFC is apexi rather than TRD btw.
04-09-2005, 10:20 PM
What you are saying is that you can have around 150bhp from the stock engine with one of these? How much for them u said?
AE86 FANATIC!!! |
04-09-2005, 10:46 PM
Apexi Super S-AFC-2 Fits all Subaru/Nissan/ Toyota/Mazda Applications
[1236-2KR] - $339.00 Free Shipping! but this is gen 2! (the blue one). was unable to find info about the gen 1. Greetings AE86 wannebe driver |
04-09-2005, 10:55 PM
is it a "plug and play" device Crimson and how much more power you gain? pics?
AE86 FANATIC!!! |
04-09-2005, 11:16 PM
the S-AFCII is a piggy back air flow converter...basically it uses a 2d map to alter the air sensor voltage to decrease or increase the amount of injector pulse at a given rpm.
i am not sure what amount of hp u gain, but u can manage it to give more or less power at user-definable rpm's (eight-point's fuel curve set in 500 RPM increments) Greetings AE86 wannebe driver |
7AGE Build | apardal | 5 | 848 |
08-02-2024 12:11 PM Last Post: apardal |
timingbelt 7age 20V!! | slowboy2 | 3 | 6,958 |
06-21-2016 09:41 AM Last Post: ditn |
7AGE to W58, cluth type? | slowboy2 | 3 | 5,471 |
05-25-2013 01:37 PM Last Post: slowboy2 |
Finding TDC on a 7AGE | oldeskewltoy | 3 | 6,064 |
03-30-2013 05:03 PM Last Post: asyrigos |
7age 16v compression | Pif | 1 | 4,694 |
10-12-2010 09:37 PM Last Post: Pif |
