'85 2door from Belgium
02-05-2010, 03:15 PM
Post: #351
I can't wait to see more.
02-05-2010, 05:19 PM
Post: #352
More updates soon, working on the custom dash. Then changing the clutch to Exedy 3-puck kit. After that get it alligned properly and start messing about with hydro e-brake.
No Smorking AE86 |
02-06-2010, 09:54 PM
Post: #353
i have a similar project... what tire size do you use for the back?
what suspension? more details please... on post or pm. |
02-06-2010, 10:13 PM
Post: #354
I have D2 coilovers, s13 lca, RCA, Driftworks tension rods, traction brackets and prothane bushings.
On the back I use different sizes depending on track/weather etc. Normally on dry I use 165/70-13, 175/60-14 everything around those sizes aswell. For wet I use mostly 195/50-15 I can also play around with spacers for more/less grip on the rear. It's a lot of playing around with sizes to get the right setup, but that's part of the fun :wink: No Smorking AE86 |
02-06-2010, 11:02 PM
Post: #355
are the d2 coilovers ok?
I have a D2 hydro e-brake what lsd? |
02-06-2010, 11:05 PM
Post: #356
they are ok, but not great. At least they were cheap
I'm thinking of buying a complete s13 to change over front/rear suspension, so I can run decent coilovers and have total adjustment on the rear. LSD is stock with 4.7r&p No Smorking AE86 |
02-06-2010, 11:07 PM
Post: #357
can you do that?
02-06-2010, 11:12 PM
Post: #358
what is "4.7r&p"
02-06-2010, 11:16 PM
Post: #359
Fronts are pretty easy, installing rear s13 subframe is a lot of work. You need to make the mounting points from nothing and they need to be perfect.
Then you have s13 lsd, full adjustment of camber etc. on rear, bigger brakes. I think changing to subframe on the rear is a big plus to building a competitive car. No Smorking AE86 |
02-06-2010, 11:19 PM
Post: #360
4.7r&p is shorter final drive. It makes you gears a bit shorter.
No Smorking AE86 |
A Portuguese Hachiroku in Belgium (lots of pictures) | Lt86 | 25 | 21,145 |
04-05-2017 08:08 AM Last Post: Lt86 |
levin from Belgium - demee76 | demee76 | 46 | 60,958 |
08-28-2015 03:06 PM Last Post: demee76 |
Belgium project | Roger | 12 | 16,066 |
08-03-2015 08:46 PM Last Post: Roger |
belgium ae86 | boedtsie | 8 | 11,533 |
06-01-2015 05:25 PM Last Post: Lt86 |
ae 86 from Belgium [Brembo installed] | seb | 67 | 83,324 |
05-19-2013 07:52 AM Last Post: seb |
