AE86 Rear Brake Upgrade - Caliper & Discs?
04-08-2008, 08:12 PM
I'm just in the process of speaking with a manufacturuer about getting a rear upgrade caliper and disc setup for the AE86.
I need to put some measurements of the existing set-up onto some forms but I dont have access to my car (its at the fabricators).
Would someone be willing to take some measurements off there car and fill in the forms if I mail them to you.
Cheers
Conrad
I'm currently taking HRT ~ Hachi Roku Therapy Big Grin
04-08-2008, 08:20 PM
If you do not have a hurry and I do not have to take apart the whole rear brakes then send it to me.
As a side note:
There are existing brake options for the rear already.
RX7 fc3s rear brakes
R32 GTR rear brakes
Cheers
Speed Industries
Hurdnerwaeldlistr. 73
8808 Pfaeffikon
Switzerland
e-mail: [email protected]
phone: +4155 420 15 69
page: http://www.speed-industries.ch
MSN: [email protected]
We have all the parts your Hachi needs
04-08-2008, 08:39 PM
hey tobias
do you have some more infos about the rear brake options?
04-08-2008, 08:57 PM
dont forget about the nissan primera rear caliper
04-09-2008, 08:05 AM
Guys in Japan use the S13 rear brakes. I have heard of people using the Cressida/Chaser rear brakes as well.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
04-09-2008, 11:03 AM
Already discussed, VW calipers + Nissan discs= 257mm rear (almost bolt-on) upgrade for cheap !
04-09-2008, 11:11 AM
The R32 kit comes from a Type M not GTR, sorry.
Diameter of discs is 257mm, 2 pot.
Kit comes complete with calipers, discs, pads, brackets, bolts.
I have one picture but I am unable to post it.
The fc3s kit comes only discs, brackets and bolts.
Has 258mm diameter.
[Image: AEU86 AE86 - AE86 Rear Brake Upgrade - C...mp; Discs?]
So you have to get some calipers and pads yourself. I can also supply these of course.
Speed Industries
8808 Pfaeffikon
Switzerland
04-09-2008, 01:36 PM
Just to be clear, this will be modern design new calipers and discs, not calipers from old RX7's and Skylines. The kit when finished will be complete. Discs, Calipers, Brackets, Lines & pads.
The kit will also match the 6 pot 286mm (on 15" wheels) kit they have for the front of the car currently.
Conrad
These are the two forms I need filling in with accurate measurements.
04-13-2008, 07:27 AM
Your in luck, I just took a bunch of different measurements of my rotors (Granted, they are aftermarket rotors. But they should be the same.)
Not measured: A, B, C, D, DD | G, H, I, J, K | O
Not listed on form: P, Q, W, X, Y, Z
E. Axle flange outside diameter:
139.0mm
F. Axle flange/hub center size
60mm
__________________________________
L. Brake rotor stud hole
14.65mm
M. Brake caliper bracket hole
10.15mm
N. PCD / bolt pattern
4x114.3mm / 4x4.5"
R. Same as 'E'
S. Brake caliper/bracket position.
S1
T. Brake Rotor/Hat overall height:
48mm
U. Rotor/Hat inner diameter:
139.7mm
V. Rotor/Hat Inside depth (calculated on 2 measurements above)
42.75mm
Check mark at bottom - Caliper is positioned 'Leading' of the rear axle.
Misc:
Brake pad contact surface/height (measured actual contact patch width on rotor):
30mm
Rotor Hat thickness @ axle flange:
5.25mm
Rotor/Hat outside diameter:
159mm
Rotor outside diameter:
231mm
Rotor thickness.
10.1-10.2mm
Quick tip: Rear rotors from a MA45/46/47 are a direct and almost identical swap to the AE86 rotors. But they are just over 1" in diameter bigger.
AE86 = 9 3/32" (231mm) - approx
MA45/MA46/MA47 = 10 5/32" (258mm) - approx
Andrew
04-13-2008, 01:50 PM
I prepare a kit of front conversion with discs of 276 mm and caliper Brembo 4 pistons.
The assembly will be Bolt on.
The discs are put at the place of the origin.
If you interested are contacted me
Toyota Team Europe Forum
my old 86: http://www.aeu86.org/viewtopic/ae-86-fro...ght=#46541
  Handbrake adjustment discs? DMC 8 1,835 03-10-2024 08:08 PM
Last Post: DMC
  Radiator oem or upgrade on racecar? Jimmi The Kid 5 5,737 06-23-2017 05:21 PM
Last Post: pack
  Rear Caliper Rebuild mad.matt 16 16,839 01-19-2017 02:19 PM
Last Post: Project D
  AE86 Rear Brake options. hachirokuGTV 66 122,734 08-27-2016 11:01 PM
Last Post: izanagi
  Ta60 carina steering upgrade? Allexz 15 15,309 06-01-2016 08:12 AM
Last Post: Allexz
