Brutal sounds comming from rear brake
06-21-2009, 09:19 AM
Hey guys, sorry to waste your time but we have a problem on my mates 86 that we cant figure out no matter what we try...
His rear left brake was doing some wierd sounds while braking (Im not sure how to describe the sound, something like whisteling perhaps?). It wasnt really loud bot it got quite annoying after some time, so he decided to change the rear pads and calipers. But instead of improving, the sound got 100x worse. Its so bad you can barely drive the car ![]() Anyone ever experienced the same problem? Thanks a lot for any help! Cheers 86ers.org AE86 x GXE10 |
06-21-2009, 01:52 PM
Have the brake pads got the anti-squeal shims installed ??
Cheers... jondee86 |
06-21-2009, 03:03 PM
Also check if the slide-pin is still straight. I once bent one on my rear brakes, which also caused some weird noises (though not as brutal as the noise you are talking about).
06-22-2009, 01:22 PM
Thanks everyone for the tips! We'll see what we can do.
![]() 86ers.org AE86 x GXE10 |
AE86 Rear Brake options. | hachirokuGTV | 66 | 126,689 |
08-27-2016 11:01 PM Last Post: izanagi |
Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 6,151 |
Engine sounds slush GZE with VIDEO ! | Okami | 13 | 15,304 |
01-03-2012 12:12 PM Last Post: Okami |
Brake master cylinder for FC3S brake conversion | Hachi Go | 8 | 14,606 |
03-03-2011 12:06 AM Last Post: filh |
DIY/How-to: E-brake adjustment for GT-S rear ends. | assassin10000 | 3 | 16,633 |
12-12-2010 11:47 PM Last Post: Hachi |
User(s) browsing this thread:
