Brutal sounds comming from rear brake
06-21-2009, 09:19 AM
Hey guys, sorry to waste your time but we have a problem on my mates 86 that we cant figure out no matter what we try...
His rear left brake was doing some wierd sounds while braking (Im not sure how to describe the sound, something like whisteling perhaps?). It wasnt really loud bot it got quite annoying after some time, so he decided to change the rear pads and calipers. But instead of improving, the sound got 100x worse. Its so bad you can barely drive the car Undecided
Anyone ever experienced the same problem?
Thanks a lot for any help!
Cheers
86ers.org
AE86 x GXE10
06-21-2009, 01:52 PM
Have the brake pads got the anti-squeal shims installed ??
Cheers... jondee86
06-21-2009, 03:03 PM
Also check if the slide-pin is still straight. I once bent one on my rear brakes, which also caused some weird noises (though not as brutal as the noise you are talking about).
06-22-2009, 01:22 PM
Thanks everyone for the tips! We'll see what we can do. Smile
86ers.org
AE86 x GXE10
  AE86 Rear Brake options. hachirokuGTV 66 122,001 08-27-2016 11:01 PM
Last Post: izanagi
  Rear ae86 rear discs & pad part numbers? J-86 4 5,814 11-30-2012 06:32 PM
Last Post: J-86
  Engine sounds slush GZE with VIDEO ! Okami 13 14,443 01-03-2012 12:12 PM
Last Post: Okami
  Brake master cylinder for FC3S brake conversion Hachi Go 8 14,094 03-03-2011 12:06 AM
Last Post: filh
  DIY/How-to: E-brake adjustment for GT-S rear ends. assassin10000 3 15,981 12-12-2010 11:47 PM
Last Post: Hachi
