Crankshaft pulley..
03-27-2008, 07:51 PM
Crankshaft pulley..
Hello there,
I need to change my crankshaft pulley, so i have a question here:
Does 4A-GE crankshaft pulley differs from 4A-FE or 3S-GE crankshtaft pulley?
White ae86 Levin
03-28-2008, 08:50 AM
Crankshaft pulley..
As far as I know the OEM 4AGE AE86 RWD crank pulley is unique. The
AE86 has two x 5-groove belts, and the outer pulley is about 10 mm
smaller in diameter.
FWD 4AGE engines have both pulleys the same size, but they will fit on
the RWD crank. You will need to adjust the alignment of the pulleys by
machining a millimetre or two off the boss, as the FWD crank pulley sits
a bit further from the engine.
AW11 (early MR2) 4AGE engines have stepped pulleys, but again they
have different offsets from the AE86 pulleys. They will fit with a bit of
adjustment. The belt alignment will not be perfect, but should be close
enough if you are running two belts.
Of course, if you are only running one belt, you will be able to get the
alignment perfect with some adjustment of the hub. AND, don't forget
to get your torque wrench and tighten the bolt to 137 Nm. If you don't
get it good and tight, it will loosen off, and you will ruin your pulley,
or even the end of your crankshaft Confused
Cheers... jondee86
03-28-2008, 06:09 PM
Crankshaft pulley..
Wow, Thank you very much for such an extensive reply Smile
White ae86 Levin
  Crankshaft stamping Blaze0010 6 1,508 06-10-2024 10:16 PM
Last Post: Blaze0010
  Crank pulley without harmonic damper Jan Pedersen 21 24,101 05-21-2014 09:50 AM
  Which new bearings for ae101 4AGZE crankshaft&connecting ditn 4 7,302 10-31-2013 06:04 PM
Last Post: ditn
  Is there anyway to LOCK the supercharger pulley on 4agZe ? Okami 6 6,100 07-06-2012 12:58 PM
Last Post: Okami
  20v/16v lightweight pulley kits 86Pilot 7 8,964 11-08-2011 04:54 PM
Last Post: 86Pilot
