Engine code
11-27-2007, 12:07 AM
Engine code
Ok I'm new to these '86 corollas (have an '86 corolla coupe) and I have been having a problem. The car starts up with a check engine light, after driving it it starts acting funny and dies off. This is frequent.
I have tried checking for codes, but I don't get it at first I have 4 blinking lights, then 7 blinking lights. If anyone can help, I appreciate it |
11-27-2007, 12:24 AM
Engine code
If you get different amounts of flashes each time, then the ECU is throwing multiple codes. Since it has a diagnostic mode, I'm assuming it's a 4AGE, you can find info about these in the factory manual which yuo can download from the main site at http://www.aeu86.org. It's best that you get that and read it through, try some of the fixes it suggests and ask the guys over here if you cant figure the problem out.
11-27-2007, 01:00 AM
Engine code
Ok well, I just checked the manual and I still don't get it, I don't see anywhere in the manual for 4 and 7 blinking lights, the closest I can get is 7 and 5 from the manual.
yes it's a 4age |
11-27-2007, 02:24 AM
Engine code
USA FSM states....
code 4 = open or short circuit in coolant temp sensor(front of engine... at water outlet) code 7 = open or short circuit in TPS signal likely the coolant sensor is decayed/broken or the connector wasn't connected TPS is a common fault. check it carefully using the FSM and reset it as per spec. Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
11-27-2007, 07:20 AM
Engine code
Fixed the problem... kind of
But now I receive 11 flashes instead of 7 sorry for asking alot. |
11-28-2007, 04:47 AM
Engine code
sorry for double post, but from what car or cars can I use the tps for the '86?
4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 7,441 |
toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 8,191 |
color code? | slowboy2 | 1 | 4,426 |
09-10-2011 08:24 PM Last Post: xrgeorg |
What is Error code 51 in the GZE? | heshan | 7 | 8,300 |
02-14-2011 03:40 AM Last Post: heshan |
Engine Light code 4 and code 8 | KD2229 | 4 | 5,663 |
08-19-2009 02:05 AM Last Post: KD2229 |
