Kaaz width doubt, OEM is out of car
04-12-2013, 01:49 PM
Hi mates,
I buyed a DAT1610 Kaaz for my kouki 86, and waiting for a new bearings kit, i saw kaaz is a bit width than OEM (about 2-3mm), it appears that these millimeters are gained in "bearing bases", axles seems seem to fit well.....
Should i mount the OEM bearings or specifics for this LSD?? This LSD is plug and play or needs different bearings?...or other modification?
[Image: AEU86 AE86 - Kaaz width doubt, OEM is out of car]
Thank you very much!!
04-12-2013, 11:04 PM
The important measurement is between the "shoulders" that the bearings
sit against when you press them on. The overall dimension is not important.
Cheers... jondee86
04-13-2013, 12:05 AM
OK! Thank you very much! Respect! i´m unconcerned now Smile
  Axle width totta Crolla 1 2,257 10-24-2023 12:20 PM
Last Post: FanIsHere
  Kaaz 1.5 way Diff - Driveshaft Compatability chrisae86 1 3,285 05-10-2021 01:02 PM
Last Post: Project D
  Rim width. Which is best.... Dino86 5 8,382 01-07-2017 03:09 PM
Last Post: Dino86
  wider rear axle,track width,suspension questions ditn 6 11,351 10-18-2016 11:50 AM
Last Post: fantapants
  Cams doubt T_AE86 47 60,600 02-12-2013 01:45 PM
