Kaaz width doubt, OEM is out of car
04-12-2013, 01:49 PM
Hi mates,
I buyed a DAT1610 Kaaz for my kouki 86, and waiting for a new bearings kit, i saw kaaz is a bit width than OEM (about 2-3mm), it appears that these millimeters are gained in "bearing bases", axles seems seem to fit well..... Should i mount the OEM bearings or specifics for this LSD?? This LSD is plug and play or needs different bearings?...or other modification? ![]() ![]() Thank you very much!! ![]() ![]() |
04-12-2013, 11:04 PM
![]() The important measurement is between the "shoulders" that the bearings sit against when you press them on. The overall dimension is not important. Cheers... jondee86 |
04-13-2013, 12:05 AM
OK! Thank you very much!
Axle width | totta Crolla | 1 | 1,689 |
Kaaz 1.5 way Diff - Driveshaft Compatability | chrisae86 | 1 | 2,811 |
Rim width. Which is best.... | Dino86 | 5 | 7,540 |
wider rear axle,track width,suspension questions | ditn | 6 | 10,076 |
Cams doubt | T_AE86 | 47 | 56,852 |
02-12-2013 01:45 PM Last Post: Bean |
