My 20v ITB installation
01-12-2005, 10:46 PM
Ian, your running the std AE86 fuel rail. The 20v runs an internal fuel rail as they are side feed injectors that are in the inlet manifold and not situated in the head like on the 16v. It is possible that your fuel pressure has been turned up by squashing the regulator thats on the end of the fuel rail.
Best way to check the pressure is to mount a gauge where the cold start injector feed is on the fuel rail. My grp A car only has 210cc injectors, but the pressure is more than standard and it makes 197ps I ran the 20v throttle bodies on my old black car with the std ecu, it can be done. If you need some help im not far away. Jamey |
01-13-2005, 09:44 AM
Cheerrs for the help/advice Jamey.
Since starting the thread and understanding a little more about injector types from 4AGE motors (especially the difference between the 16v and 20v) I figured the rail was the std 16v unit once I'd found out the injectors were not 20v. I must get a pressure gauge on there at some time. We did have one on our old hayabusa powered westi but I cant find it now. When all this new stuff gets fitted onto the car I'd like to put it on the rollers and see what its making (I reckon maybe 150bhp ish at the flywheel). At the same time I'd also like to use a wide band 02 monitor so we can see how the fueling is doing. The biggest problem right now is not being able to work with the ECU. Regards Ian. ![]() |
01-15-2005, 08:40 PM
Well,
today I made a difference to my hachi ![]() if you remember my ITBS looked like this behind those trumpets ![]() So, after approx 1 hour of cleaning gasket sealant and some metal cleaner they looked like this. ![]() I was at the autosport show yesterday and managed to pick up a set of pipercross C1050 trumpet socks direct from their stand at half the retail price. ![]() ![]() And after a bit of spannering...hmmmmmmm.... trumpets ![]() ![]() Gasket seal was cleaned up and the socks installed and zip tied into place. What with getting the timing sorted and fitting these the car is pulling like a trooper - its really smoothed things out and it revs hard as you like again. I was so happy I decided to navigate an entire roundabout - sideways LOL. Regards Ian. ![]() |
01-15-2005, 08:47 PM
That looks very nice, look forward to seing your car at Silverstone next weekend!
01-15-2005, 08:49 PM
Looking good!
Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
01-15-2005, 10:37 PM
Real nice!
Now i want videos of that sideway driving! ![]() ![]() |
01-15-2005, 11:09 PM
Nice work..may I ask what that metal canister with all those rubber hoses coming out of it is for? Some kind off vacuum-reservoir maybe?
01-16-2005, 03:19 AM
Ivan,
correct - its a vancuum canister - takes feeds from each throttle body - I haven't got a clue where they come from/go ? Is it something to do with the brakes - I think some can be vacuum assisted ? Some chevey engines make use of a vacumm can to aid the distributer ? Ummmmm...I dunno. Regards Ian. ![]() |
01-16-2005, 11:25 AM
Vacuum canister has hoses from each TB to the canister. There air gathers, so MAP sensor can read vacuum in the intake. Based on vacuum, tps, intake temperature and some else parameteres, ECU is calcualting fuel volume.
01-16-2005, 07:06 PM
AHA so thats why the stock MAP ECU can work around ITB's
grtz thomas My car weighs only 496 kilograms with the 4age in place! |
4A-GE 20V ITB bolt patterns | kjb | 7 | 12,350 |
02-27-2016 01:23 PM Last Post: kjb |
How to install 20V ITB on 16V head | Mr.komp | 7 | 12,065 |
12-28-2015 05:35 PM Last Post: pack |
Machining Pistons to run 20v head... And FCR's on a 20v? | PazzaAE86 | 2 | 5,204 |
09-15-2013 01:08 AM Last Post: jondee86 |
20v itb inlet manifolds | totta Crolla | 24 | 27,189 |
12-14-2012 12:21 PM Last Post: Bean |
4AGE 20v ITB vacuum instructions on Intecracing.com | JAVResistance | 17 | 34,514 |
05-07-2011 05:50 AM Last Post: jondee86 |
User(s) browsing this thread: 46 Guest(s)
