New engine setup, what performance will I get?
12-11-2006, 07:48 AM
So I got new high compression pistons and I'm getting the head/block milled with a metal head gasket. The pistons are 11:1 and with the milling I won't be far from 12:1. I just got my Crower full race cams, 288/298 with less than 9mm lift. I'm running dual 40mm Mikunis, header, exhaust, and adjustable cam gears. What do think the hp/tq figures would be around?
I'm balancing the bottom end(OEM crank/rods), light weight flywheel, have MSD 6AL/blaster coil, and TRD valve springs if that matters any.
Thanks,
g
  weir performance email filh 2 5,769 06-14-2015 05:37 PM
Last Post: oldeskewltoy
  4 Link setup and Traction brackets Jezza_hr 5 11,909 07-21-2014 09:12 PM
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 9,758 10-30-2013 11:18 PM
  Can't get my car started! phill 92 16 17,418 09-16-2013 05:23 PM
Last Post: Alex170984
  Weir Performance rear upgrade kit for AE86 heshan 5 10,625 07-22-2013 09:11 PM
Last Post: heshan
