Sick little Hachi
11-06-2006, 09:22 PM
Sick little Hachi
This is what you need to do:
http://www.club4ag.com/faq%20and%20tech_...0Codes.htm Otherwise we will just keep on guessing from a distance.. A wheel to steer the front of the car A pedal to steer the rear |
11-06-2006, 09:49 PM
Sick little Hachi
Cheers Nohachi,will try this and let you know how i get on.
The A.d.d Clinic Automotive Detailing: http://www.addperformance.ie [email protected] JDM Import specialist: A.d.d - Ireland |
11-09-2006, 02:35 AM
Sick little Hachi
Hi Guys,
Went out to the car today and did the diagnostic check looped the wire in the diagnostic port and watched.here's what happened: The engine check light flashed 5 times then paused for 0.5 sec and flashed 6 times then paused for0.5 sec and flashed 10 times Does this mean there is a code 56 wrong with the car and if so what is code 56??,also can anyone tell me what the flashing 10 times is about. Anyway i then disconnected the NEGATIVE on the ECU and went about cleaning all the EARTHS on the car,when i reconnected the ECU and started it was fine.Drove great for the whole evening Can anyone put a bit of light on this (hope it behave's,fingers X'd) The A.d.d Clinic Automotive Detailing: http://www.addperformance.ie [email protected] JDM Import specialist: A.d.d - Ireland |
11-09-2006, 10:20 AM
Sick little Hachi
cab32,
A good! Atleast you got her driving again!! Bad grounds suck As for the codes, good question, I think its time someone put a nice little writeup up about checking the error codes with a nice list of what they mean, who feels up to it? Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
11-09-2006, 12:15 PM
Sick little Hachi
Hi mate,
It feels great have her back on the road again,will start doing a bit of research into the error codes.Thanks again The A.d.d Clinic Automotive Detailing: http://www.addperformance.ie [email protected] JDM Import specialist: A.d.d - Ireland |
11-09-2006, 02:28 PM
Sick little Hachi
Mux213 Wrote:As for the codes, good question, I think its time someone put a nice little writeup up about checking the error codes with a nice list of what they mean, who feels up to it?robokill? cab32, good that you got the car running again with no problem at least now. I hope the problem will gone forever 1985 AE86 (ハチロク) Levin - Summer time daily driver |
11-09-2006, 02:49 PM
Sick little Hachi
there are codes http://www.troublecodes.net/Toyota/
OBD1 Codes 1 Normal Condition. 2 Air Flow Meter signal. 3 Ignition signal. 4 Engine Coolant Temperature Sensor signal. 5 Oxygen Sensor. 6 RPM signal (Crank Angle Pulse). 7 Throttle Position Sensor signal. 8 Intake Air Temperature Sensor signal. 9 Vehicle Speed Sensor signal. 10 Starter signal. 11 Switch signal. 11 ECU/ECM. 12 Knock Control Sensor signal. 12 RPM signal. 13 Knock Control CPU (ECM). 13 RPM signal. 14 Turbocharger Pressure. 14 Ignition signal. 21 Oxygen Sensor. 22 Engine Coolant Temperature Sensor signal. 23 Intake Air Temperature Sensor signal. 24 Intake Air Temperature Sensor signal. 25 Air-Fuel Ratio Lean. 26 Air-Fuel Ratio Rich. 27 Sub Oxygen Sensor signal. 28 No. 2 Oxygen Sensor signal. 31 Air Flow Meter signal (Vacuum Sensor signal). 32 Air Flow Meter signal. 34 Turbocharger Pressure signal. 35 Turbocharger Pressure Sensor signal. 35 HAC Sensor signal. 41 Throttle Position Sensor signal. 42 Vehicle Speed Sensor signal. 43 Starter signal. 51 Switch signal. 52 Knock Sensor signal. 53 Knock Sensor signal. 54 Inter-cooler ECM signal. 71 EGR System. 72 Fuel Cut Solenoid signal. 78 Fuel Pump Control signal. 81 TCM Communication. 83 TCM Communication. 84 TCM Communication. 85 TCM Communication. also in here http://www.club4ag.com/faq%20and%20tech_...0Codes.htm |
11-09-2006, 06:49 PM
Sick little Hachi
It was probably spitting 3 codes..
11-13-2006, 05:48 PM
Sick little Hachi
Hi guys,
Big thanks for the help it's been a few days now and all is still good,cheers Oldskull for the nice comments hope it lasts for good as well mate. And S.K thanks for the codes,big help to alot of people mate.And yes Ivan141 i think you are probably right about the car spitting out three codes.5 , 6 and ten 10 all make sense. Thanks again guys,hope i can be of help to you sometime. The A.d.d Clinic Automotive Detailing: http://www.addperformance.ie [email protected] JDM Import specialist: A.d.d - Ireland |
Trueno Conversion but with a little twist / question. | Okami | 16 | 14,932 |
05-19-2012 06:41 AM Last Post: danielt |
Little starting Problem | AshCampbell | 5 | 5,622 |
06-04-2009 07:50 AM Last Post: jondee86 |
Oil pump pics/info - a little help? | assassin10000 | 1 | 3,104 |
01-31-2009 06:57 PM Last Post: assassin10000 |
Need a little HELP with the diff rebuild | lamera | 5 | 4,920 |
03-29-2007 11:48 PM Last Post: lamera |
had a sick idea... | WKD RWD | 9 | 7,922 |
02-16-2006 10:52 PM Last Post: dAYTONA |
