Ta60 carina steering upgrade?
05-14-2016, 03:36 PM
(This post was last modified: 05-14-2016 03:41 PM by Allexz.)
Hello
Is it possible to upgrade this type of steering? https://drive.google.com/open?id=0B6ig5_...mphYnItNFU The car is hard to drive because of the steering having a life of its own with 15inch 195 tires Don´t Think About The Past, Live In The Present And Dream About Tomorrow |
05-16-2016, 04:54 AM
(This post was last modified: 05-16-2016 04:55 AM by roman.)
Is yours a wagon?
Get a rack and pinion setup from another Carina(AA60 etc), Celica (AA60 etc), or Corona (ST141 etc). and then you'll have way better steering, it will bolt staight in but you probably need to change steering columns too which is a bit of a mish. |
05-17-2016, 04:55 PM
Its a sedan
4 doors I was thinking of taking the daihatsu charmant steering which is like the ae86 /ae71 Don´t Think About The Past, Live In The Present And Dream About Tomorrow |
05-18-2016, 12:15 AM
Thats the first worm & roller TA60 I`ve seen.
Get a TA60 crossmember with rack & pinion+inner and outer tie rods as well as steering column, and simply swap it all in If you want more steering lock (and this will work with your current worm & roller steering), get AE86 P/S steering arms also. 1x AE86 84` Zenki Coupè Levin 4A-GE 20v 1x AE86 83' Zenki Coupe Levin 4A-GE 16v 1x TA60 82' Sedan 2T 8V 1x TA40 78` MK1 Zenk/Pre-Facelift Wagon 4A-GE 16v |
05-18-2016, 04:44 AM
(05-18-2016 12:15 AM)Rascal21 Wrote: If you want more steering lock (and this will work with your current worm & roller steering), get AE86 P/S steering arms also. This doesnt work, the bolt hole centres are different. The shortest arms you can get that fit are from a PS corona/carina/celica. Which are popular because they also fit into Cressidas, celica supra, etc. |
05-18-2016, 06:35 PM
And where do i find these parts?
There is like 5 ta60 on the rode in sweden!!! Also want to do a coilover conversion eventually But that seems to also be a hard thing Don´t Think About The Past, Live In The Present And Dream About Tomorrow |
05-18-2016, 09:26 PM
Come to Norway, we have a few in scrapyards and so forth, you can probs pick everything for a "tusenlapp"
Same as any other car, check facebook, forums etc get to know people, same as with AE86`s etc you wont get much done sticking to local sources For coilovers anything AE86 will fit, I recommend AE86 coilovers with AE86 hubs, brakes etc. Another solution is to cut off your shock tubes and leave 20-30mm and weld on brackets for Golf struts (scrapyard) and get some cheapo Golf coilovers. 1x AE86 84` Zenki Coupè Levin 4A-GE 20v 1x AE86 83' Zenki Coupe Levin 4A-GE 16v 1x TA60 82' Sedan 2T 8V 1x TA40 78` MK1 Zenk/Pre-Facelift Wagon 4A-GE 16v |
05-19-2016, 01:55 PM
Maybe I should go there Do you know any scrapyard pages with ta60s in ?
(05-18-2016 09:26 PM)Rascal21 Wrote: Come to Norway, we have a few in scrapyards and so forth, you can probs pick everything for a "tusenlapp" Don´t Think About The Past, Live In The Present And Dream About Tomorrow |
05-19-2016, 08:52 PM
The Carina was sold in large quantities in Finland, so you can also try your luck there.
05-23-2016, 12:00 PM
I actually have a scrapped TA60 at hand but I`m gonna use the rack in my TA40.
But they are up and around here and there on different facebook pages etc, so I`ll keep my eyes open for parts cars, if any pop up I can ask what they want for column+rack+crossmember. 1x AE86 84` Zenki Coupè Levin 4A-GE 20v 1x AE86 83' Zenki Coupe Levin 4A-GE 16v 1x TA60 82' Sedan 2T 8V 1x TA40 78` MK1 Zenk/Pre-Facelift Wagon 4A-GE 16v |
Carina TA63 GT-TR - Suspension?? | danny 86 | 11 | 8,442 |
01-30-2021 03:39 PM Last Post: danny 86 |
Radiator oem or upgrade on racecar? | Jimmi The Kid | 5 | 5,861 |
06-23-2017 05:21 PM Last Post: pack |
Carina drivers! - Coilovers for a TA60/62 | nyberrg | 2 | 6,380 |
06-05-2017 10:03 AM Last Post: nyberrg |
TA60/TA62 Carina; what fits? | nyberrg | 10 | 15,969 |
10-12-2016 12:57 PM Last Post: The Doctor |
A60 Carina rear axel, AE86 parts | nyberrg | 3 | 6,361 |
09-02-2015 09:21 PM Last Post: banpei |
