Valve sound
04-02-2007, 07:54 PM
Post: #31
Valve sound
valve adjust is always good but toyta's run on 10w 40 form the factory
04-02-2007, 08:06 PM
Post: #32
Valve sound
Thanks for your reply Robokill
04-02-2007, 08:32 PM
Post: #33
Valve sound
My ValveĀ“s sounds louder too after engine service, i use 10w-40 aral oil and bosh oil filter, the sound disappears when i rev up the engine, just in idle it sounds a bit bad.... Sad oil pressure is ok by the way
04-02-2007, 09:01 PM
Post: #34
Valve sound
My valve sound is nearly zero when my engine is warm. When i rev there is no valve sound.
When i am idle and cold there is a lot of valve sound.
Fuel pressure is normal too.
04-03-2007, 09:13 PM
Post: #35
Valve sound
Mine does a similar thing and I suspect it is piston slap as the noise goes away when the engine warms up, not too much of a problem I believe though Smile
If the engine has been re-built has someone fitted new rings into a worn bore ?
TVIS can also sometimes make this kind of noise.
04-03-2007, 10:54 PM
Post: #36
Valve sound
misschien kan iemand dit even vertalen voor me?
ik ben er zeker van dat hij een kantelende zuiger heeft,als de motor op temperatuur is dan is het weg ,kan geen kwaad maar zal ongetwijfeld wat olie gebruiken denk ik.een ruim drijfstang lager zal juist harder worden naarmate de olie warm word(en dus dunner)
[edit: Translation]
TE71 corolla also thinks it's most likely piston slap causing the problem.. it cant do much harm, but will use some oil. If it was a bearing it would grow worse with increasing engine temperature.
[/edit]
[Image: AEU86 AE86 - Valve sound]
04-06-2007, 10:35 AM
Post: #37
Valve sound
Adjusting the valve clearances on a 4AGE is not a
simple process like on a pushrod engine. You have
to measure the clearances correctly, then, if they are
out of tolerance, replace the shims that are sitting
on top of the valve lifters.
If the clearances were set correctly when the engine
was rebuilt, it is unlikely that they will be out of
tolerance after only 40,000 km. But by all means
check the clearances to be certain.
While you are in there, check the condition of your
cam belt tensioner idler bearing. I have had a tensioner
making a noc... noc... sound when the engine was idling.
It sounded exactly like a big end bearing knock, and
even had my mechanic fooled for a while.
BTW, a mechanic's stethoscope is handy for tracking
down mysterious noc... noc... sounds :wink:
Cheers.... jondee86
04-13-2007, 10:04 AM
Post: #38
Valve sound
jondee
i think that this is something i had in mind (i'm talking about the cam belt) or something similar.
Thanks a lot for the remark
04-13-2007, 10:15 AM
Post: #39
Valve sound
check TE71 corolla's reaction he is a mechanic as a professional. On top of that he had a 2tg engine
04-13-2007, 12:33 PM
Post: #40
Valve sound
Thanks robokill
I just forgot to thank TE71 for his contribution Undecided
  4AGE Valve Buckets Scored Steller Engineering 2 882 10-06-2023 05:34 PM
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 1,350 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  HKS valve springs totta Crolla 3 2,161 05-25-2022 10:24 PM
  Valve clearance leon205gti 7 8,574 11-25-2016 03:24 AM
  16v oversize valve seats harkes 9 12,409 09-20-2016 05:04 PM
