What Diff Oil For a Clutch plate diff?
12-06-2011, 02:11 AM
what oil should i use in my clutch plate trd 2way , its macking a clacking noise when turning , diff is 100percent, what oil could reduce this noise?
comma 80w/90 castrol b373 ? any advice welcome thanks |
12-06-2011, 04:15 AM
I run Motul 90PA with no problems on my TRD, Castrol SAF-XJ works also well with clutch lsdĀ“s.
Castrol b373 does sound right, too Do you know which oil is in your diff right now? 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
12-06-2011, 10:17 AM
I run Castrol SAF-XJ for three years now, no problem.
Any 75W140 for limited slip should do. |
12-06-2011, 02:43 PM
im not sure what oil is in it, i was also recomended silkolene boa 90ls anyone have any info
12-06-2011, 07:25 PM
on Driftworks some guys recommend this oil for clutch-plate diffs
it's for Racing differentials Redline Lightweight shockprove http://www.redlineoil.com/product.aspx?pid=43&pcid=8 there's also a friction modifier you could try adding to your current oil |
12-06-2011, 09:06 PM
Castrol SAF-XJ or Redline Lightweight shockproof (reduce the noise significantly)
But if you have a really noisy "clack" you should rebuild it. I don't know what you do with your car, but when you're drifting it's recommended to rebuild your LSD every year or so. |
12-07-2011, 04:37 AM
Is this a brand new diff? You need to do the break-in figure 8's if so, which will quiet down the chatter quite a bit.
Andrew |
12-09-2011, 09:15 PM
MOTUL 90PA with My KAAZ 2 ways LSD
(80W/90 GL-5 recommended by kaaz) : http://www.kaazusa.com/techhelp2.html |
12-16-2011, 11:14 AM
best oil for differential are the motul 75/150
1976 TA28 CELICA 1978 PUBLICA PICKUP 1980 4WD PICKUP 1983 AE86 LEVIN 2007 AYGO |
sorry 75/140
Mocal oil cooler & sandwitch plate ordered | Gtsi-R | 48 | 55,011 |
trans oil, lsd oil change | Apolan | 9 | 17,009 |
Spindle dimensions, backing plate bolt pattern | Rascal21 | 18 | 21,391 |
03-13-2014 11:45 AM Last Post: Rascal21 |
Oil cooler -> low oil pressure | Jan Pedersen | 24 | 30,191 |
Urgent replies needed DIFF OIL + refresh | Okami | 6 | 6,470 |
06-17-2012 09:56 PM Last Post: Okami |
