What engine do I want in my AE86?
03-11-2013, 06:14 PM
Post: #31
So to summarise:
+4 degrees ignition timing
Auto MR2 ecu
TRD Header
Buddy club exhaust
Slightly higher compression
= +30whp !!
Why didn't Toyota think of that instead of spending fortunes
making the 20v ?
TBH if your engine made 140 flywheel horsepower I would be surprised.
Sorry 'bout that...
TC
03-11-2013, 06:36 PM
Post: #32
10 degrees more timing, the usdm cars run 10 degrees advance stock, the mr2 ecu was an "on accident" discovery. replaced the stock one due to issues with one from my sister's auto mr2 and the car ran a lot harder. and a full point jump in compression(9.4:1 vs. 10.4:1).
03-11-2013, 06:41 PM
Post: #33
10 degrees with the timing connector jumped.
16 degrees with it disconnected and in normal running mode.
Post: #34
also my car made 127 wheel with the stock bluetop with the same ecu and TVIS deleted... I had a freak car as my best friend has the identical car with a rebuilt bluetop. He's as good a driver as I am and his car had identical mods, I would always walk on him in 3rd and 4th. My car has always pulled hard on the top end.
Sorry about the thread jack by the way! You know how it is, you put in your 2 cents when a question is asked and some @$$ has to negate everything you say and call you a liar...
03-11-2013, 06:43 PM
Post: #35
totta Crolla Wrote:10 degrees with the timing connector jumped.
I was referring to with connector jumped... but yes we were both right lol
03-11-2013, 06:45 PM
Post: #36
I'm not an @$$
I'm hoping that the OP does not follow what
you have done and then expect to get the same result.
He won't
FACT.
03-11-2013, 06:51 PM
Post: #37
I agree, I've seen identical builds before result in massive hp differences. I was just recommending something that wasn't as expensive as a 20v(especially since he already has a redtop)...
I think you'd be happier with ITBS, a nice set of cams, and a decent tune. Rather than throwing a lot of money into a swap that doesn't make much more power than a nicely done 16v.
Blacktop stock- +/-150 hp
Blacktop modded- 165-185 hp
Redtop stock- +/- 130 hp
Redtop modded- 155-175hp
I understand 10 hp may be a lot to some people, but I'll sacrifice 10 hp to save $1000.00
03-11-2013, 06:54 PM
Post: #38
and by modded I'm implying cams, ecu, itbs, bolt ons...
03-11-2013, 10:10 PM
Post: #39
Yea you could get a V8, cummings diesel, top fuel dragster V8 or why not a experimental camshaftless koenigsegg engine? Wink
If you want a Blacktop I think you should go for it. Just read up on the swap properly so you and the company don't get any too big unexpected troubles.
Also if you go through with the engine swap I can take that Redtop of your hands Wink
03-11-2013, 10:12 PM
Post: #40
totta Crolla Wrote:I'm not an @$$
He won't
FACT.
+1 one for good advice. Thanks for taking the time totta!
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 8,146 10-30-2013 11:18 PM
  stand alone ECU but i want to keep my rev clock williep12 28 28,641 08-25-2010 02:26 PM
Last Post: thanhngo
  Heat... I want some heat! amigaguy 8 9,751 09-29-2009 05:44 PM
Last Post: -Mister2-
  my hachi don't want to start... BOOMEX 8 6,990 01-11-2008 12:05 AM
Last Post: maggkrabar
  Want to yank some stuff off my car. Need help. sho_shane 11 9,281 07-02-2007 04:31 PM
Last Post: sho_shane
User(s) browsing this thread: 21 Guest(s)
