What engine do I want in my AE86?
03-11-2013, 06:14 PM
Post: #31
So to summarise:
+4 degrees ignition timing Auto MR2 ecu TRD Header Buddy club exhaust Slightly higher compression = +30whp !! Why didn't Toyota think of that instead of spending fortunes making the 20v ? TBH if your engine made 140 flywheel horsepower I would be surprised. Sorry 'bout that... TC An analogue brain in a digital World |
03-11-2013, 06:36 PM
Post: #32
10 degrees more timing, the usdm cars run 10 degrees advance stock, the mr2 ecu was an "on accident" discovery. replaced the stock one due to issues with one from my sister's auto mr2 and the car ran a lot harder. and a full point jump in compression(9.4:1 vs. 10.4:1).
03-11-2013, 06:41 PM
Post: #33
10 degrees with the timing connector jumped.
16 degrees with it disconnected and in normal running mode. An analogue brain in a digital World |
Post: #34
also my car made 127 wheel with the stock bluetop with the same ecu and TVIS deleted... I had a freak car as my best friend has the identical car with a rebuilt bluetop. He's as good a driver as I am and his car had identical mods, I would always walk on him in 3rd and 4th. My car has always pulled hard on the top end.
Sorry about the thread jack by the way! You know how it is, you put in your 2 cents when a question is asked and some @$$ has to negate everything you say and call you a liar... |
03-11-2013, 06:43 PM
Post: #35
totta Crolla Wrote:10 degrees with the timing connector jumped. I was referring to with connector jumped... but yes we were both right lol |
03-11-2013, 06:45 PM
Post: #36
I'm not an @$$
I'm hoping that the OP does not follow what you have done and then expect to get the same result. He won't FACT. An analogue brain in a digital World |
03-11-2013, 06:51 PM
Post: #37
I agree, I've seen identical builds before result in massive hp differences. I was just recommending something that wasn't as expensive as a 20v(especially since he already has a redtop)...
I think you'd be happier with ITBS, a nice set of cams, and a decent tune. Rather than throwing a lot of money into a swap that doesn't make much more power than a nicely done 16v. Blacktop stock- +/-150 hp Blacktop modded- 165-185 hp Redtop stock- +/- 130 hp Redtop modded- 155-175hp I understand 10 hp may be a lot to some people, but I'll sacrifice 10 hp to save $1000.00 |
03-11-2013, 06:54 PM
Post: #38
and by modded I'm implying cams, ecu, itbs, bolt ons...
03-11-2013, 10:10 PM
Post: #39
Yea you could get a V8, cummings diesel, top fuel dragster V8 or why not a experimental camshaftless koenigsegg engine?
If you want a Blacktop I think you should go for it. Just read up on the swap properly so you and the company don't get any too big unexpected troubles. Also if you go through with the engine swap I can take that Redtop of your hands |
03-11-2013, 10:12 PM
Post: #40
totta Crolla Wrote:I'm not an @$$ +1 one for good advice. Thanks for taking the time totta! A wheel to steer the front of the car A pedal to steer the rear |
toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 7,987 |
stand alone ECU but i want to keep my rev clock | williep12 | 28 | 27,849 |
08-25-2010 02:26 PM Last Post: thanhngo |
Heat... I want some heat! | amigaguy | 8 | 9,486 |
09-29-2009 05:44 PM Last Post: -Mister2- |
my hachi don't want to start... | BOOMEX | 8 | 6,773 |
01-11-2008 12:05 AM Last Post: maggkrabar |
Want to yank some stuff off my car. Need help. | sho_shane | 11 | 9,018 |
07-02-2007 04:31 PM Last Post: sho_shane |
User(s) browsing this thread: 24 Guest(s)
