What engine
11-13-2010, 03:57 PM
What engine
Ive done a bit of research into the toyota 4age engine but still not 100% on what engine I have. cant really get a good look at the side of the block to see if its 3 or 7 ribs on it.
I take it that its large port? Heres some pics ![]() ![]() |
11-13-2010, 07:29 PM
What engine
hmmmmmm, can't really tell what block you have from this angle... but I am sure you have a TVIS engine, and if it hasn't been taken apart, or opened up before, it is likely to have 10 to 1 pistons instead of 9.4 to 1. I'm making that guess based on the T/B vacuum connections, and your engines lack of other vacuum parts.
Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
11-13-2010, 07:41 PM
What engine
oldeskewltoy Wrote:hmmmmmm, can't really tell what block you have from this angle... but I am sure you have a TVIS engine, and if it hasn't been taken apart, or opened up before, it is likely to have 10 to 1 pistons instead of 9.4 to 1. I'm making that guess based on the T/B vacuum connections, and your engines lack of other vacuum parts. very simple all non afm models in EU are running the 10:1 comp pistons. Big port head and if its 3 or 7 ribs doesn't really matter there is a 99% chance you have a 40mm crank with 18 mm piston pins. There is a not a valve cover that changes that ![]() Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
12-02-2010, 09:07 AM
What engine
mms Wrote:Ive done a bit of research into the toyota 4age used engines but still not 100% on what engine I have. cant really get a good look at the side of the block to see if its 3 or 7 ribs on it. I am just wondering if this is just an ordinary engine or having good quality of engine. Let me know. ![]() |
12-02-2010, 11:34 AM
What engine
ordinary
12-02-2010, 12:34 PM
What engine
Who knows what's inside.
I aint stock, at least exhaust header isn't. |
12-02-2010, 01:32 PM
What engine
Note the oil drain to the rear of the head.
This indicates late model block. Likely high comp pistons, 7rib, 42mm crank. ![]() No oil drain (low comp block, likely 3rib, 40mm crank) ![]() Note that there are many intermediate versions. 7rib low comp blocks etc. Lots of info here. Oil drain is easiest to see to determine block type. http://www.club4ag.com/faq_and_tech_page...0Block.htm http://www.skynet.ie/~eireae86 |
12-02-2010, 01:37 PM
What engine
Where can you see the oil drain on those pictures? I just cant find them
![]() ![]() AE86 GT - SR20DET BlackTop //// Trackday beater Citroen C4 Coupe VTR - 1.6HDi //// Streetcar |
12-02-2010, 05:19 PM
What engine
12-02-2010, 05:56 PM
What engine
i see there is a map sensor on the firewal
so i think it is an 10 to 1 comp. engine with T-vis. 3 rib or 7 rib.. '87 levin coupé ![]() |
toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 8,351 |
Need engine,any engine | Apolan | 25 | 19,358 |
10-29-2006 06:55 PM Last Post: ZaX |
