Where to find the informations on the gearbox/engine
01-26-2009, 08:14 PM
Hi.
My TE71 was swapped with a Toyota Diesel engine Angry
So tomorrow i am going around to check what there is.
But where can i find for example T50 on the gearbox, or 2 TC 3 TC
Sorry to ask but i am more on Honda stuff (which i know where to look at for the info).
And how to recognize the steerings "Worm and Roller" and "rack and pinions"
Thank you Thumbs up!
01-26-2009, 08:37 PM
Diesel! Huh
Then the engine should most probably be a 1C...
T50 should be readable on top of the gearbox...
You can see here how the T50 and K50 (just in case) should look:
http://www.aeu86.org/viewtopic/ae86/p/96200#96200
[Image: AEU86 AE86 - Where to find the informati...box/engine]
01-26-2009, 08:42 PM
banpei Wrote:Diesel! Huh
Yes Sad
1C ? ok if you say so Big Grin
i will put some updates on my TE71 topic with photos.
I went to a guy, he had 2C engine (diesel) or something like that, and i checked the gearbox i couldn't find anything Sad
thanks for the link Thumbs up!
01-26-2009, 08:45 PM
If you have a 1C engine it is probably mated with a W51 gearbox a 3SGE swap would be a good substitute for the 4AGE. >Smile
01-26-2009, 08:50 PM
banpei Wrote:If you have a 1C engine it is probably mated with a W51 gearbox a 3SGE swap would be a good substitute for the 4AGE. >Smile
you are speaking for me for the moment Big Grin i am spending 4 hours a day on different website to understand Toyota logic but for the moment Banging head
so W51 will suit a 3SGE ? What engine is that ? (i am going on wiki)
01-26-2009, 08:53 PM
ouhhh yaeeaaahh 2.0 liter of the MR2, some VVTI, some Lexus.
Perfect for me Hurray!
i have to find out what gearbox i have to be sure
but has it is on top, i cannot check ?!
01-27-2009, 06:18 PM
I checked it is a 2C engine.
I found a 3SFE at the scrapyard. Can it fit ?
Thanks (i am fed up diesel Angry )
02-06-2009, 01:20 PM
The T50 gearbox does not have "T50" or anything like that written on it. You can identify the T50 gearbox as it is a split case design, which is sort of rare.
A W series gearbox is a more regular sandwich style gearbox.
02-06-2009, 01:22 PM
Jonny Rochester Wrote:The T50 gearbox does not have "T50" or anything like that written on it. You can identify the T50 gearbox as it is a split case design, which is sort of rare.
Thanks.
I try to do a photo of it today, so you tell me as i cannot find out Sad
02-07-2009, 01:15 PM
doubt you can see something but... Confused
  Emergency help find store with bearings france Allexz 5 5,039 09-12-2019 03:24 PM
Last Post: Allexz
  ford type 9 gearbox with 4age engine filh 29 50,320 01-11-2015 01:02 PM
Last Post: filh
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 8,396 10-30-2013 11:18 PM
  Were to find 4AG-ZE gaskets in toyota diy? fax0815 17 16,562 05-28-2013 10:17 PM
Last Post: ditn
  Question: Where I can find this fender flare? winchi.c 3 5,413 05-01-2011 09:58 AM
Last Post: Bentley
