Wires getting hot!
11-21-2007, 10:07 PM
Wires getting hot!
The two wires on the grill light button in the car are getting so hot i cant touch them, i noticed it from a burning smell. Any idea what would cause this???
11-21-2007, 10:30 PM
Wires getting hot!
Did you use a relay for the lights or you give them power directly from the switch ?
AE86 FANATIC!!! |
11-21-2007, 11:20 PM
Wires getting hot!
Whatever the factory wiring is. Was working fine till this started happening bout two weeks ago.
11-22-2007, 01:25 AM
Wires getting hot!
Maybe some wire is half cut. The resistance gets high and more heat is generated...
Keeping the AE86 alive! |
11-22-2007, 08:28 AM
Wires getting hot!
Wires get hot because there is more current (amps) flowing in the
circuit than the wire was designed to carry. Adding extra load (lights wired in parallel) or changing to higher Wattage bulbs could do it. A short circuit will do it also... if the track to earth doesn't draw enough current to blow the fuses. You should disconnect that lighting circuit until you can find and fix the fault. Otherwise, make sure your insurance is up to date, and carry a fire extinguisher Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
11-22-2007, 02:53 PM
Wires getting hot!
Its stock wiring and stock blubs, so it must be a short! could it be a bad ground???
11-22-2007, 11:18 PM
Wires getting hot!
No. A bad ground causes high resistance and less current in the
wires. But it can cause locallised heating at the point of high resistance... that is, at the faulty connection. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
11-23-2007, 12:57 AM
Wires getting hot!
Ok thanks for that..
Ignition switch plug and wires | Blaze0010 | 3 | 335 |
getting new sparkplugs, or keep away ? | MC_JP | 5 | 6,145 |
09-19-2014 11:35 PM Last Post: Project D |
LHD W.G (West Germany) wires from dimmer & dash switch to headlight relays? | Rascal21 | 11 | 14,675 |
07-07-2014 09:16 AM Last Post: Ivan141 |
Engine cranks slowly when hot... but starts | Dino86 | 9 | 13,629 |
02-03-2014 08:04 PM Last Post: Dino86 |
Hot oil filter - a problem? | harkes | 5 | 6,458 |
01-03-2014 09:33 PM Last Post: Apsogos |
