help, engine dies at startup - (56k Warning - SOLVED)
05-19-2007, 12:16 PM
hey bean,
good luck, I'm sure it will turn out to be something easy since the car was running before you changed the HG. The only question I would have is why the HG broke in the first place. Simple old age, or as a result of another problem with your engine that you're now running into. Anyways, give that girl of yours some 1st place priority, that indeed is important, cars will wait patiently for you, girls wont ![]() Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
05-19-2007, 12:37 PM
Mux213 Wrote:hey bean, haha she's #1 for sure - don't worry ![]() I know loads about patience - my SX is waiting to be finished more then 3 years now and it'll be at least another one or two 'till it'll be driveable again (not finished as this is never going to happen with a race project) ![]() the HG went down to mahoosive abuse by me on swiss mountain passes and by the previous owner on the ring ![]() ![]() AE86 ex-daily |
05-21-2007, 09:15 PM
engine is still not running, here the pics as promised...
![]() following pictures are with the engine set to TDC - have I overlooked something (hopefully yes, so I can get it running again quick snap) ![]() ![]() ![]() ![]() ![]() ![]() any suggestions? AE86 ex-daily |
05-21-2007, 09:44 PM
Do you have the nockpins right ?
![]() One time in the past i haven make a mistake and have both nockpins above. No compresion on all of the cill ![]() Qeustion Do you have compression sparks fuel all yes, your ignition timing is bad Starlet p8 si turbo @ 1.0 bar grey 6,4 sec-> 100 Starlet P9 si turbo @ 1.2 bar black 5,8 sec-> 100 KTM 950 SE ->100 3,2 sec 105 Db ![]() xt660r ->100 4,5 sec BMW 1100 GS->100 4 sec |
05-21-2007, 09:45 PM
Hmm..the valves on the rightmost cilinder look a bit off compared to the rest.Almost like some coating has been burnt off, maybe it's just my imagination. Looks like you aligned everything just fine, although it's hard to tell with the distributor after it's been out.
05-21-2007, 09:59 PM
I have look @ my spare 4age.Seems like that your timing camschafts is good.
Picture of the ignitor @ my 4age, also everything on zero. ![]() Starlet p8 si turbo @ 1.0 bar grey 6,4 sec-> 100 Starlet P9 si turbo @ 1.2 bar black 5,8 sec-> 100 KTM 950 SE ->100 3,2 sec 105 Db ![]() xt660r ->100 4,5 sec BMW 1100 GS->100 4 sec |
05-21-2007, 10:08 PM
compression is good (>12) again, checkd it after had reassembled everything
... sparks are good too ![]() @ae86 - how can I set ignition timing without the engine runnig at least rough? when I try to start it trys to fire twice realy short and then dies ![]() any more hints? will try a new set of plugs just in case - despite them being good... AE86 ex-daily |
05-21-2007, 10:19 PM
RTFM OF 4AGE
![]() Is your distributor on the same spot as before? Do you have the 4age manual ?? iff not send mee a PM Starlet p8 si turbo @ 1.0 bar grey 6,4 sec-> 100 Starlet P9 si turbo @ 1.2 bar black 5,8 sec-> 100 KTM 950 SE ->100 3,2 sec 105 Db ![]() xt660r ->100 4,5 sec BMW 1100 GS->100 4 sec |
05-21-2007, 10:27 PM
You have found the manual on my site
![]() Jos Starlet p8 si turbo @ 1.0 bar grey 6,4 sec-> 100 Starlet P9 si turbo @ 1.2 bar black 5,8 sec-> 100 KTM 950 SE ->100 3,2 sec 105 Db ![]() xt660r ->100 4,5 sec BMW 1100 GS->100 4 sec |
ae86 Wrote:RTFM OF 4AGE AE86 ex-daily |
High-beam warning lamp | Mylesmck | 4 | 1,622 |
AE86 Driveshaft too long? [SOLVED] | MyCrazyGarage | 12 | 7,747 |
07-28-2022 10:48 PM Last Post: banpei |
toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 8,279 |
AVO Suspension from MCN Motorsport warning | 4000GT | 1 | 3,875 |
07-19-2013 04:48 AM Last Post: 4000GT |
How to: Repair low fuel warning sender | Sanity Clause | 2 | 37,375 |
11-22-2012 09:21 AM Last Post: ZaX |
