help, engine dies at startup - (56k Warning - SOLVED)
05-19-2007, 12:16 PM
hey bean,
good luck, I'm sure it will turn out to be something easy since the car was running before you changed the HG. The only question I would have is why the HG broke in the first place. Simple old age, or as a result of another problem with your engine that you're now running into.
Anyways, give that girl of yours some 1st place priority, that indeed is important, cars will wait patiently for you, girls wont Smile
05-19-2007, 12:37 PM
Mux213 Wrote:hey bean,
haha she's #1 for sure - don't worry Smile
I know loads about patience - my SX is waiting to be finished more then 3 years now and it'll be at least another one or two 'till it'll be driveable again (not finished as this is never going to happen with a race project) Wink
the HG went down to mahoosive abuse by me on swiss mountain passes and by the previous owner on the ring Smile so not that bad - I cleand the head of any casting marks as well so it'll be fine for some more trashing... I like cars but my mechanical sympathy is next to none existent Smile as I like working on the car although I swear a lot when I need several hours for a 5min job just because some engineer was stoopid to think ahead that some bolts need to be replaced with the engine in situ...
05-21-2007, 09:15 PM
engine is still not running, here the pics as promised...
[Image: AEU86 AE86 - help, engine dies at startu... - SOLVED)]
following pictures are with the engine set to TDC - have I overlooked something (hopefully yes, so I can get it running again quick snap)
any suggestions?
05-21-2007, 09:44 PM
Do you have the nockpins right ?
One time in the past i haven make a mistake and have both nockpins above.
No compresion on all of the cill Banging head
Qeustion
Do you have
compression
sparks
fuel
all yes, your ignition timing is bad
Starlet p8 si turbo @ 1.0 bar grey 6,4 sec-> 100
Starlet P9 si turbo @ 1.2 bar black 5,8 sec-> 100
KTM 950 SE ->100 3,2 sec 105 Db Tongue
xt660r ->100 4,5 sec
BMW 1100 GS->100 4 sec
05-21-2007, 09:45 PM
Hmm..the valves on the rightmost cilinder look a bit off compared to the rest.Almost like some coating has been burnt off, maybe it's just my imagination. Looks like you aligned everything just fine, although it's hard to tell with the distributor after it's been out.
05-21-2007, 09:59 PM
I have look @ my spare 4age.Seems like that your timing camschafts is good.
Picture of the ignitor @ my 4age, also everything on zero.
05-21-2007, 10:08 PM
compression is good (>12) again, checkd it after had reassembled everything
... sparks are good too Sad fuel was ok when I took it apart... will check tomorrow...
@ae86 - how can I set ignition timing without the engine runnig at least rough?
when I try to start it trys to fire twice realy short and then dies Angry
any more hints? will try a new set of plugs just in case - despite them being good...
05-21-2007, 10:19 PM
RTFM OF 4AGE Blush
Is your distributor on the same spot as before?
Do you have the 4age manual ??
iff not send mee a PM
05-21-2007, 10:27 PM
You have found the manual on my site Smile
Jos
ae86 Wrote:RTFM OF 4AGE Blush
Is your distributor on the same spot as before? yup, maybe half a milimiter different
Do you have the 4age manual ?? yes, i do
  High-beam warning lamp Mylesmck 4 1,619 07-21-2023 07:44 AM
  AE86 Driveshaft too long? [SOLVED] MyCrazyGarage 12 7,745 07-28-2022 10:48 PM
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 8,277 10-30-2013 11:18 PM
  AVO Suspension from MCN Motorsport warning 4000GT 1 3,874 07-19-2013 04:48 AM
Last Post: 4000GT
  How to: Repair low fuel warning sender Sanity Clause 2 37,374 11-22-2012 09:21 AM
User(s) browsing this thread: 30 Guest(s)
