help, engine dies at startup - (56k Warning - SOLVED)
05-21-2007, 10:45 PM
Maybe the coil is bad? Dunno. If you're sure you have fuel and spark, have a sniff at the exhaust. If there's a lot of fuel vapor coming out, it could be the engine is flooding with fuel. Had this on a friends car a few years back. It refused to start, so we pulled the efi fuse and ran the starter long enough for the plugs do blow dry, then reinstalled it. It then fired up on the first try.
Oh and by the way, if those pics of the cams are with the engine at TDC, then something is wrong.. at least if they are the stock cams. You should be able to see a dimple in the camshaft through the oil filler hole with the engine at TDC. FABRICA MI DIEM, PVNC! |
05-21-2007, 11:00 PM
ae86 Wrote:Do you have the nockpins right ? @ivan: looking at this picture (attachment below) in full size, you can just about make out the knockpin, according to the above pic from ae86 this is correct for TDC ![]() I'll test fuel tomorrow... AE86 ex-daily |
Ivan141 Wrote:Oh and by the way, if those pics of the cams are with the engine at TDC, then something is wrong.. at least if they are the stock cams. You should be able to see a dimple in the camshaft through the oil filler hole with the engine at TDC. Seems that he has no stock camshaft ?, de dimple is not there the but the cams are in the right position ![]() your camshaft timing is correct!! Starlet p8 si turbo @ 1.0 bar grey 6,4 sec-> 100 Starlet P9 si turbo @ 1.2 bar black 5,8 sec-> 100 KTM 950 SE ->100 3,2 sec 105 Db ![]() xt660r ->100 4,5 sec BMW 1100 GS->100 4 sec |
05-21-2007, 11:02 PM
ae86 Wrote:Ivan141 Wrote:Oh and by the way, if those pics of the cams are with the engine at TDC, then something is wrong.. at least if they are the stock cams. You should be able to see a dimple in the camshaft through the oil filler hole with the engine at TDC. as far as I know they are stock - it's a non CAT, AFM equipped Swiss hatchi... and the my pic does look very similar to this: Mux213 Wrote:Well in case he can't find a backing plate, does this help? I'm confused ![]() ![]() ![]() |
05-21-2007, 11:09 PM
This dimple ivan meens
![]() Starlet p8 si turbo @ 1.0 bar grey 6,4 sec-> 100 Starlet P9 si turbo @ 1.2 bar black 5,8 sec-> 100 KTM 950 SE ->100 3,2 sec 105 Db ![]() xt660r ->100 4,5 sec BMW 1100 GS->100 4 sec |
05-21-2007, 11:14 PM
well it's there - I can just about see it on the full size picture...
AE86 ex-daily |
05-21-2007, 11:19 PM
![]() ![]() Starlet p8 si turbo @ 1.0 bar grey 6,4 sec-> 100 Starlet P9 si turbo @ 1.2 bar black 5,8 sec-> 100 KTM 950 SE ->100 3,2 sec 105 Db ![]() xt660r ->100 4,5 sec BMW 1100 GS->100 4 sec |
05-22-2007, 10:36 AM
anyone any other last minute tips before I go to the garage?
AE86 ex-daily |
05-22-2007, 10:38 AM
Create check list now and proceed, don't use your memory only.
05-22-2007, 10:42 AM
Unplug injectors, so no extra fuel is wasted.
Attach timing light to #1 lead. Swing engine over using starter. Watch timing mark, adjust to 10degrees btdc. Timing is now set. If you leave distributor lined up as is it may be at 0degrees in stead of 10 ![]() No reconnect injectors. Try to start. If no start? -Check injectors have +12v -Check coil still has 12v -Check fuel pump is turning on. -Check for air lock in fuel line. -Loosen 22 on fuel rail, crank until fuel squirts out ![]() -----REMEMBER TO RETIGHTEN Turn on ignition lights, perform a dignostic. Engine wont start if error code 6? No G/Ne signals Let us know how you get on. http://www.skynet.ie/~eireae86 |
High-beam warning lamp | Mylesmck | 4 | 1,619 |
07-21-2023 07:44 AM Last Post: banpei |
AE86 Driveshaft too long? [SOLVED] | MyCrazyGarage | 12 | 7,745 |
07-28-2022 10:48 PM Last Post: banpei |
toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 8,277 |
AVO Suspension from MCN Motorsport warning | 4000GT | 1 | 3,874 |
07-19-2013 04:48 AM Last Post: 4000GT |
How to: Repair low fuel warning sender | Sanity Clause | 2 | 37,374 |
11-22-2012 09:21 AM Last Post: ZaX |
User(s) browsing this thread: 27 Guest(s)
