removing clocks
09-12-2006, 02:22 PM
removing clocks
so does anyone know how to remove the dash clocks the speedo and stuff,
does the dash have to come out or do you just remove the black plastic cover then take the clock out |
09-12-2006, 02:45 PM
removing clocks
I think it's just the steering wheel, dash cover and then the clock. Nothing more. Check the FSM, you can download it from this site, the link is in the technical FAQ
09-12-2006, 03:21 PM
removing clocks
yeah just downloaded it earlier, yet to look through it
suppose i will probably have to remove my cage as well, or atleast unbolt it anyway |
09-12-2006, 03:48 PM
removing clocks
I didn't need to remove the steering wheel: I bent the black cover a bit and I was able to squeeze it between the dash and the steering wheel (in lowest position). However this may damage (e.g. break in half) your cover so it's better to do it by removing the steering wheel
09-12-2006, 05:26 PM
removing clocks
my steering wheel is only held on by 6 allan key bolts anyway since it is an aftermarket one
09-12-2006, 08:12 PM
removing clocks
I'd prefer the original...1 huge nut....much easier to work with than those allen bolts.
09-12-2006, 09:40 PM
removing clocks
trueno is the way Wrote:my steering wheel is only held on by 6 allan key bolts anyway since it is an aftermarket oneAuch! But is the steering wheels smaller than the oem steering wheel? 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
09-12-2006, 09:42 PM
removing clocks
banpei Wrote:trueno is the way Wrote:my steering wheel is only held on by 6 allan key bolts anyway since it is an aftermarket oneAuch! yes very much so very small |
09-13-2006, 09:16 AM
removing clocks
trueno is the way Wrote:yes very much soThen I think it should be possible to remove the black cover by putting the steeringwheel in the lowest position without much effort. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
09-13-2006, 11:12 AM
removing clocks
huh
my steering column isnt adjustable |
removing light switch ? (fixed) | MC_JP | 10 | 16,936 |
09-18-2014 05:16 PM Last Post: MC_JP |
Removing front window trim | zenki | 7 | 12,417 |
09-07-2014 08:36 PM Last Post: Ivan141 |
Removing interior plastics | Jezza_hr | 3 | 5,536 |
03-18-2013 11:41 PM Last Post: Ivan141 |
Removing brake servo (booster) | totta Crolla | 1 | 3,896 |
09-17-2011 01:40 PM Last Post: totta Crolla |
Removing unnecessary wires.. some identification help! | 4000GT | 3 | 5,129 |
08-20-2011 04:40 AM Last Post: 4000GT |
