7afe with 4agze tranny
06-19-2008, 07:25 PM
Im building a 7agze with a 4agze tranny (FWD).
Now ive already gor the tranny and it bolts on nicely.
Now the challange here is to get the flywheel/clutch combo correctly.
I was first thinking of a custom flywheel, but thats just to expensive for now. Got an offer from fidanza for a custom flywheel at $1500.
The other option would be to get a 7afe clutch that fits the 4agze spline.
Now ive been talking to both fidanza and spec clutches about this and both offered me a clutch solutoioon.
Fidanza is cheaper, but wont provide the correct bearings and pilot tool, while spec will provide the correct bearing etc.
Now the question, fidanza or spec? I havent got any experience with their clutches so hopefully you guys can enlighten me
06-21-2008, 08:06 PM
Did you know Toda make the flywheel for 7AFE Flywheel? The part # for Toda is 22100-7AF-000. Basically, The 7AFE Flywheel is 212mm just like 4AGE but only have 6 bolt to bolt on to the crankshaft.
Maxwell Arancon
Vice President
PASS RACING INC
148 S.8th Ave, Unit-F
City of Industry, USA
[email protected]
http://www.passracing.com
[Image: AEU86 AE86 - 7afe with 4agze tranny]
06-21-2008, 09:33 PM
thanx for the info Max, ill take a look at it.
Im also checking the 225mm flywheel from a 3TC.
I measured the 4agze flywheel I have here and its ~230mm, so if im correct I have a late E58. Toyota didnt put identifycations on the tranny Undecided
06-23-2008, 07:53 AM
All GZE trans is E serious that is the same of the SW20 Turbo. Did you know The LSD of AW11 GZE and SW20 Tubro are the same part #? Hope will give you some idea.
Maxwell Arancon
Vice President
PASS RACING INC
[email protected]
06-28-2008, 11:17 PM
Sounds like an appropriate combination man1 Good work.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
  tranny fluid drift 10 12,656 04-21-2012 06:10 AM
Last Post: assassin10000
  Sr86 engine/tranny mounts szmk89 1 3,537 10-31-2010 06:38 PM
Last Post: szmk89
  7AFE + 4AGE head + turbo ...Anyone ? Uzelac 13 32,634 09-02-2010 08:23 AM
Last Post: Sambo
  TRANNY ae86xye 3 4,149 09-22-2008 04:19 AM
Last Post: F0Bman
  Which engine/tranny mounts??? Aram 7 6,906 08-12-2008 06:03 AM
Last Post: F0Bman
