Ae85 swap 4age.
04-06-2021, 06:27 PM
Ae85 swap 4age.
Hello Smile
I would like to change me 3A-U from my ae85 for a bluetop, has someone already done it? I would like some information for the wirring Smile thanks you very much
04-07-2021, 09:52 AM
Ae85 swap 4age.
It has been done before and we even had a forum member who simply swapped a 4A-GE head on to a 3A-U bottom, making it a 1.5 litre 3A-GE. But that was a lot of effort for little gain.
The procedure should be mostly the same as for the SR5 to GT-S swap (4A-C to 4A-GE) as described by Assassin10000, with the difference that the AE85 has a K50 gearbox instead of a T50 gearbox. The SR5 has the T50, but is clutch operated instead of hydraulic, hence you need the 4A-GE bellhousing.
Your rear axle is also a different axle (S302/S312/S314) than the AE86 (most of them are T283). You can keep the S axle, but it's harder to find a LSD for it. If you can live with an open diff it shouldn't be an issue. Wink
[Image: AEU86 AE86 - Ae85 swap 4age.]
04-07-2021, 10:25 AM
Ae85 swap 4age.
Hello, thank you for the response ! I will study the subject of "assassin". I forgot to specify that I have an automatic gearbox on my ae85
04-07-2021, 01:14 PM
Ae85 swap 4age.
Do you wish to retain the automatic gearbox? If not you also need to swap the radiator as this is commonly used for cooling both the engine and gearbox.
04-07-2021, 01:18 PM
Ae85 swap 4age.
I'm going to switch to a manual gearbox. changing the hoses does not keep the radiator?
04-07-2021, 01:36 PM
Ae85 swap 4age.
I have the A40 automatic transmission on my Carina and the A42DL that's in the AE85/AE86 is a similar gearbox. The Carina has a separate oil cooling for the gearbox at the underside of the radiator. But I couldn't find this for the AE85 in the diagrams. so it could be that it is cooled differently...
Anyway, if it's the same as with the Carina the radiator has less capacity due to the oil cooling part. You can do without but your water temperature may get into the red zone quicker.
04-07-2021, 03:27 PM
Ae85 swap 4age.
ok, i'm thinking of adding an electric fan Wink
04-07-2021, 10:10 PM
Ae85 swap 4age.
Hey, i'm from belgium aswell.
If there is anything you need parts wise you can always send me a msg.
Might be able to help you out.
Grtz
04-07-2021, 10:16 PM
Ae85 swap 4age.
Hello , private message send !
  ae85 kickdown cable MIGGZFSU 0 3,092 05-04-2017 04:23 PM
Last Post: MIGGZFSU
  HELP! need AE85 lisse/lime cluster diagram AE86_DRIFTER_ 0 3,504 06-27-2016 11:38 PM
Last Post: AE86_DRIFTER_
  AE85 axle dif hub to ae86?? Melo 7 10,163 04-30-2012 11:38 PM
Last Post: Melo
  Approaches to making the AE85 4WD 4000GT 11 20,772 02-17-2011 10:08 PM
Last Post: jameslad
  AE85 vs AE86 revsx 6 12,939 07-22-2010 07:32 AM
Last Post: 45psi
