Poll: Would you choose carbs (Weber, Dellorto, Mikuni...) instead of the stock EFI of the 4AG?
I'd choose carbs
I'd choose EFI
I'd choose ITB (independed throttle bodies, added later by MODSmile)
[Show Results]
Carbs for the 4AG
06-17-2005, 12:30 PM
Post: #31
Carbs for the 4AG
ooh.. new option on the poll...
I change my vote from Carbs to ITB...
Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62
06-17-2005, 12:46 PM
Post: #32
Carbs for the 4AG
Thx MOD! Smile Good thought...
06-17-2005, 03:54 PM
Post: #33
Carbs for the 4AG
I'm more EFI minded myself..and I think the choice between carbs and stock EFI is a bit unfair. Your paying money for the carbs (at least in normal situations), and if you would invest the same amount in your EFI you would also get nice performance.
At least EFI has less hassle with tuning and can handle changing circumstances much better. The downside is that for ITB throttle response your going to need the usually ridiculously expensive ITB's. People over here charge more for the throttle bodies than they would for a 16v 4age engine.
Still as far as I'm concerned, EFI>Carbs...(predictable electrical engineer point of view)
06-17-2005, 04:12 PM
Post: #34
Carbs for the 4AG
How can the stock injectors and throttle body be cleaned and inspected for wearing out? Anyone know a good and relatively cheap way to clean the injectors at home?
My current "intake side" is worse than bad. Sad High fuel consumption, not enough power...
Ivan, your oppinion is also true IMHO. I forgot to calculate that if you spend as much money for the EFI system as you would for carbs, it also gets better.
06-17-2005, 04:16 PM
Post: #35
Carbs for the 4AG
hey sutter,
There is no better way then sonic cleaning your injectors but that can be expensive.
Another option that works is to buy one of those bottles of injector cleaner you mix in with you gastank, poor it into a bottle, put the injectors in the bottle, and let them soak for a couple of days. But it doesn't do as good a job as sonics..
06-17-2005, 09:04 PM
Post: #36
Carbs for the 4AG
I've thinking about the second way too.
Anyways...what do sonics mean? Dumb question
06-17-2005, 09:10 PM
Post: #37
Carbs for the 4AG
SutteR Wrote:I've thinking about the second way too.
Ultrasound generator. This is a vane with hot detergent fluid + ultrasound generation.
06-17-2005, 09:14 PM
Post: #38
Carbs for the 4AG
Ultrasound??? What fooor? Dumb question This is really interesting...
06-17-2005, 09:30 PM
Post: #39
Carbs for the 4AG
SutteR Wrote:Ultrasound??? What fooor? Dumb question This is really interesting...
When you try to clean some surface - you can use ultrasound with success.
It just helps to separate different materials one from another.
06-17-2005, 09:35 PM
Post: #40
Carbs for the 4AG
Thanks! Since I don't know any place to make this sonics cleaning and I'm not sure if it will help gaining some performance out of my hachi I'll buy some fluid and clean the injectors myself.
After that I can swap to carbs... Tongue
  Question about 4AG 20v Engine Block CHACAMAN 1 1,599 06-10-2022 05:17 PM
Last Post: oldeskewltoy
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 10,906 02-10-2020 06:39 PM
Last Post: Power_uP
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 4,269 11-05-2016 01:34 AM
  SOME 4AG valve spring specs oldeskewltoy 5 13,297 05-04-2015 01:17 PM
Last Post: Project D
  tacho issues using haltech e6x on 4ag 20v bluehachi 5 7,009 06-05-2013 06:34 PM
Last Post: Rasteirinho
