Carbs for the 4AG
06-17-2005, 12:30 PM
Post: #31
Carbs for the 4AG
ooh.. new option on the poll...
I change my vote from Carbs to ITB... Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
06-17-2005, 12:46 PM
Post: #32
Carbs for the 4AG
Thx MOD!
06-17-2005, 03:54 PM
Post: #33
Carbs for the 4AG
I'm more EFI minded myself..and I think the choice between carbs and stock EFI is a bit unfair. Your paying money for the carbs (at least in normal situations), and if you would invest the same amount in your EFI you would also get nice performance.
At least EFI has less hassle with tuning and can handle changing circumstances much better. The downside is that for ITB throttle response your going to need the usually ridiculously expensive ITB's. People over here charge more for the throttle bodies than they would for a 16v 4age engine. Still as far as I'm concerned, EFI>Carbs...(predictable electrical engineer point of view) FABRICA MI DIEM, PVNC! |
06-17-2005, 04:12 PM
Post: #34
Carbs for the 4AG
How can the stock injectors and throttle body be cleaned and inspected for wearing out? Anyone know a good and relatively cheap way to clean the injectors at home?
My current "intake side" is worse than bad. ![]() Ivan, your oppinion is also true IMHO. I forgot to calculate that if you spend as much money for the EFI system as you would for carbs, it also gets better. |
06-17-2005, 04:16 PM
Post: #35
Carbs for the 4AG
hey sutter,
There is no better way then sonic cleaning your injectors but that can be expensive. Another option that works is to buy one of those bottles of injector cleaner you mix in with you gastank, poor it into a bottle, put the injectors in the bottle, and let them soak for a couple of days. But it doesn't do as good a job as sonics.. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
06-17-2005, 09:04 PM
Post: #36
Carbs for the 4AG
I've thinking about the second way too.
Anyways...what do sonics mean? ![]() |
06-17-2005, 09:10 PM
Post: #37
Carbs for the 4AG
SutteR Wrote:I've thinking about the second way too.Ultrasound generator. This is a vane with hot detergent fluid + ultrasound generation. |
06-17-2005, 09:14 PM
Post: #38
Carbs for the 4AG
Ultrasound??? What fooor?
06-17-2005, 09:30 PM
Post: #39
Carbs for the 4AG
SutteR Wrote:Ultrasound??? What fooor? When you try to clean some surface - you can use ultrasound with success. It just helps to separate different materials one from another. |
06-17-2005, 09:35 PM
Post: #40
Carbs for the 4AG
Thanks! Since I don't know any place to make this sonics cleaning and I'm not sure if it will help gaining some performance out of my hachi I'll buy some fluid and clean the injectors myself.
After that I can swap to carbs... ![]() |
Question about 4AG 20v Engine Block | CHACAMAN | 1 | 1,758 |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 11,544 |
Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 4,367 |
SOME 4AG valve spring specs | oldeskewltoy | 5 | 13,631 |
05-04-2015 01:17 PM Last Post: Project D |
tacho issues using haltech e6x on 4ag 20v | bluehachi | 5 | 7,284 |
06-05-2013 06:34 PM Last Post: Rasteirinho |
