Differential ae86 lsd kouki
01-20-2011, 04:29 PM
Good evening!!
Does somebody knows if this differential have different axles thickness? other thickness right and other left?
01-20-2011, 07:39 PM
Hello,
the kouki axle has a bigger axle diameter than the zenki.
There is no difference beween right and left.
Hope this helps?
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
01-20-2011, 09:18 PM
yes...... i know this Sad but in my group at the right has big axle and the left has bigger Banging head !!!! i have axles for ta22 and both of them at the left side has a small "shaking" !! both of them is in good condition(diff & axle )
any idea?? Crying
i have 2 pics if they can help!!
[Image: AEU86 AE86 - Differential ae86 lsd kouki]
01-21-2011, 01:42 AM
Those pictures look healthy.
TA22 should have the same LSD as a zenki AE86 afaik.
If the parts in the picture look equally good on both sides, then you probably have a broken lsd, this will cause a lot of 'slop' on the axle. It is a very common problem on ae86 original LSD's, the metal plate holding the gears that the axleshafts connect to breaks pretty easily.
01-21-2011, 02:17 AM
Yes TA22 does have the same axle spline as zenki AE86.
But I´m sure the TA22 axle is shorter because the axle housing of a TA22 is narrower than a AE86 housing.
But it could be compensated, because you need to shorten the TA22 axles, from what I remember 5mm each sind to fit the AE86 LSD.#
Don´t know if this answers any of your questions... Smile
01-21-2011, 09:59 AM
so.... im starting to open the diff and then check for the length of the axles...
Lets begin.....
wish me good luck ......... Confused
01-21-2011, 07:43 PM
so..... the results!!!
diff is in good condition (gears & housing) but he want repair kit ( check photos to confirm )
<a target="_blank" href="http://img443.imageshack.us/i/dsc03592t.jpg/"><img src="http://img443.imageshack.us/img443/9232/dsc03592t.th.jpg" border="0"></a><br>
<a target="_blank" href="http://img199.imageshack.us/i/dsc03593b.jpg/"><img src="http://img199.imageshack.us/img199/7631/dsc03593b.th.jpg" border="0"></a><br>
now the problems.......
1) the left side gear unfortunately is bigger than the right one Banging head
first pics is for the right side gear with axle and other 2 is the left one
the gap between the gear and the axle is obviously!!
<a target='_blank' href='http://img34.imageshack.us/i/dsc03587s.jpg/'><img src='http://img34.imageshack.us/img34/7027/dsc03587s.th.jpg' border='0'></a>
<img src="http://img15.imageshack.us/img15/7360/dsc03588t.th.jpg" border="0"></a><br>
<a target="_blank" href="http://img402.imageshack.us/i/dsc03589j.jpg/"><img src="http://img402.imageshack.us/img402/3919/dsc03589j.th.jpg" border="0"></a><br>
<a target="_blank" href="http://img545.imageshack.us/i/dsc03590c.jpg/"><img src="http://img545.imageshack.us/img545/3066/dsc03590c.th.jpg" border="0"></a><br>
2) something i notice from the first time but i didn't care about that....
according to the manual "align the marks on the case and case cover" page 6
<a target="_blank" href="http://img40.imageshack.us/i/lsd6.gif/"><img src="http://img40.imageshack.us/img40/7890/lsd6.th.gif" border="0"></a><br>
I mark the case before remove it and then i see the factory marks wrong!!
<a target="_blank" href="http://img152.imageshack.us/i/dsc03594q.jpg/"><img src="http://img152.imageshack.us/img152/2619/dsc03594q.th.jpg" border="0"></a><br>
<a target="_blank" href="http://img510.imageshack.us/i/dsc03595l.jpg/"><img src="http://img510.imageshack.us/img510/2235/dsc03595l.th.jpg" border="0"></a><br>
btw...
i remove the case cover with all the parts and... from one side i found 3 parts and from the other side two!! is this right? i think no.....
<a target="_blank" href="http://img262.imageshack.us/i/imag0337p.jpg/"><img src="http://img262.imageshack.us/img262/2193/imag0337p.th.jpg" border="0"></a><br>
<a target="_blank" href="http://img15.imageshack.us/i/dsc03596px.jpg/"><img src="http://img15.imageshack.us/img15/6766/dsc03596px.th.jpg" border="0"></a><br>
After a quick search i found this photo and check what includes this diff and i haven't one part!!!
<a target="_blank" href="http://img256.imageshack.us/i/ae86oemlsdrebuild3.jpg/"><img src="http://img256.imageshack.us/img256/309/ae86oemlsdrebuild3.th.jpg" border="0"></a><br>
this is right or the guy that he sold me forgot to put it inside?? ( he said that its never opened )
01-21-2011, 10:02 PM
It appears you are missing a clutch plate, and one of the gears is clearly a kouki model (i assume you tried them on the same axle).
The clutch plates are easily replaced with a rebuild kit (check T3, toyota or Weir performance). The little brass plate in pic 2 is usually not included in rebuild kits but can be bought from toyota (I did once).
I might be able to find you a spare gear as I have one or two broken LSD's that I have no real use for, but I'd suggest you look around locally first.
01-21-2011, 11:25 PM
Yes i tried it at the same axle!
i search at local toyota for the start and..... i send a pm at the person that sold me... ( is from here and i hope to respond to my message Crying )
01-22-2011, 09:40 PM
Edited for dumb.
  Rear Differential rebuild chenfon 10 9,329 11-20-2020 12:18 AM
Last Post: totta Crolla
Exclamation Some information for those who are about to restore their differential krullibull 0 3,234 06-06-2015 12:44 AM
Last Post: krullibull
  differential lock % damusto 8 9,423 04-17-2013 10:01 PM
Last Post: damusto
  T283 - AE86 differential / LSD problems ZaX 0 5,081 03-04-2012 08:10 PM
  Differential help uv7x77 4 4,902 12-05-2010 10:18 PM
User(s) browsing this thread: 12 Guest(s)
