High oil pressure
10-13-2005, 12:25 PM
High oil pressure
can somebody tell me more what to do with high oil pressure.
10-13-2005, 12:34 PM
High oil pressure
New piston rings maybe?
RX-8 -- AE86 -- |
10-13-2005, 01:03 PM
High oil pressure
The by-pass valve in the oil pump is mayby stock.....
I still play with cars...... |
10-13-2005, 01:10 PM
High oil pressure
First tell us how high the oil pressure is at the moment (on the scale).
My last engine had broken 2 piston rings and the oil pressure was very high back then. Easiest way to check that is to pull the crankcase ventilation tube from the inlet manifold and see how much smoke is coming out..big clouds/oil coming out of the air filter indicate a dead engine. Also: does it idle normally? My old broken engine couldnt keep running at idle anymore when it was warmed up. FABRICA MI DIEM, PVNC! |
10-13-2005, 01:27 PM
High oil pressure
High oil pressure it’s not a bad thing at all. I don’t know why you are so worried about it.
How much high is it on the scale? Fun is not the straight line! |
10-13-2005, 01:39 PM
High oil pressure
I'm a bit more worried about my low oil pressure at idle these days..it's at the half of the scale (lowest line in safe area), and drops even a bit under that when the engine idles lower than 900rpm.
On the other hand unusually high oil pressure can be an indicator that there is a lot of blow-by past the pistons. FABRICA MI DIEM, PVNC! |
10-13-2005, 02:31 PM
High oil pressure
Ivan141 Wrote:I'm a bit more worried about my low oil pressure at idle these days..it's at the half of the scale (lowest line in safe area), and drops even a bit under that when the engine idles lower than 900rpm.Same here! During driving it stays around 70-80% of scale and during idle it drops a little bit under minimum line. I’m using Valvoline full synt. 5w-40. It was the same with Castrol RS 10w-60. Fun is not the straight line! |
10-13-2005, 03:11 PM
High oil pressure
I almost don't drive it above 3k RPM because of the pressure.
10-13-2005, 03:16 PM
High oil pressure
i shouldn't be to worried if i were you.
That's the region it should be in! Your instruction book (if you got one ...) states that this is the perfect value for a warm 4A-GE. And if the pressure is really to high, it's gonna drop down automaticly someday "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
10-13-2005, 03:42 PM
High oil pressure
The Doctor Wrote:And if the pressure is really to high, it's gonna drop down automaticly someday LOL! Thanks for the info guys! 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
High-beam warning lamp | Mylesmck | 4 | 1,296 |
Engine stress at high speeds | gh0st | 6 | 2,251 |
4AGE 16V engine overheat when at high speed | chenfon | 32 | 20,260 |
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 20,468 |
Early EDM non-cat 4A-GE 16v Bluetop Fails emissions (high co) | Rascal21 | 41 | 32,225 |
08-21-2016 04:51 PM Last Post: ray |
