ITB from bike engine ?
04-02-2009, 04:17 PM
dr.occa Wrote:the only difference is available intake manifolds. they'll have to be custom fabbed. That's exactly what i am interested in, ITB, EFI and megasquirt (or something similar). Are these project presented somewhere? regards |
04-02-2009, 05:05 PM
Uzelac Wrote:Mate, your posts are real informing but aint' answers on my question as for running a MAP setup, as someone may have mentioned before, w/ a stand alone ECU, MAP or alpha-n(TPS) are easily possible depending on your cam profiles. unfortunately, i'm always pressed for time so i rarely document the process of my projects. i'll usually just post up the final product. maybe this time around i'll give it a shot. here's somewhat of a process i've begun documenting on www.86garage.com. ![]() "Strictly All Things 86" |
04-03-2009, 12:55 AM
Something like this....
[img]http://lh3.ggpht.com/_APKI3b0oh_A/SdUl0mGHLeI/AAAAAAAABLo/yXN-xRUPk78/s288/DSC05023.JPG"[/img] Honda CBR 1000RR 2006 ITB with dual injectors, tps ... (43mm body, not sure about injectors) ....would be ok ? + Megasquirt + MAP + some other stuff ? |
04-03-2009, 05:05 AM
Silver Tops throttles goes for around 200 euro
while the black tops goes for another 300 euro shipping depending where your country is. |
04-03-2009, 06:00 AM
Uzelac Wrote:Something like this.... yep, those should be quite "adequate" to say the least. ![]() "Strictly All Things 86" |
04-03-2009, 09:27 AM
panda_tureno86 Wrote:Silver Tops throttles goes for around 200 euro.....shipping depending where your country is. Bike's ITB's are more avaliable, much cheaper and often comes with injectors/tps/map... This Honda ITB is 100€ as seen on that picture, and there is no shipping since everything can be found locally ![]() |
toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 8,424 |
Stock Bigport Engine + ITB?s?! | pack | 36 | 54,784 |
06-15-2013 07:19 AM Last Post: jondee86 |
Need engine,any engine | Apolan | 25 | 19,747 |
10-29-2006 06:55 PM Last Post: ZaX |
