KAAZ differential oil
08-04-2006, 08:57 PM
What differential oil has to be used for two-way KAAZ LSD?
AE86 GTS '84 Red Top |
08-05-2006, 03:55 AM
I think you can use Motul 90PA whitout problems. I use this Oil in my Cusco 1.5 way and all OK
Regards ![]() |
08-05-2006, 01:32 PM
I use Esso GL-5 80W90 LSD oil - exactly the same spec as KAAZ oil, but MUCH cheaper. I can get you some for £5 per litre
08-08-2006, 07:51 AM
Bad_Dog Wrote:What differential oil has to be used for two-way KAAZ LSD? Bad_Dog, thanks for posting this question for me. ![]() 1984 Toyota Corolla 4AGE 20v 2007 Subaru Impreza STi |
08-08-2006, 09:58 AM
I would use nothing less than full synthetic with such an expensive rearend.
08-08-2006, 10:59 AM
in the KAAZ USA site it says:
" Oil for Kaaz LSD It is important to use 80W/90 GL-5 specification gear oil on Kaaz LSD. We highly recommend using our own Kaaz LSD fluid. DO NOT USE SYNTHETIC BASE OIL ON KAAZ LSD. Kaaz LSD may not function smoothly. " Now you chose if you want synthetic or not .... I use Motul 90PA |
08-08-2006, 11:23 AM
gon Wrote:in the KAAZ USA site it says: I've heard this before but did not know if it's only a rumor. 1984 Toyota Corolla 4AGE 20v 2007 Subaru Impreza STi |
08-08-2006, 03:54 PM
a rumor publicated in the KAAZ USA official web site ?
08-08-2006, 04:19 PM
ummmmm I'll never put Syntetic oil in my LSD. The brands of lsd said than syntetic oil crapt LDSs.
Regards ![]() |
08-08-2006, 04:24 PM
Can anyone come up with some links about this?
It would be a bummer if synthetics dont go well with LSD's... synthetics are a better choice for your gearlife than mineral oils. FABRICA MI DIEM, PVNC! |
Kaaz 1.5 way Diff - Driveshaft Compatability | chrisae86 | 1 | 2,443 |
Rear Differential rebuild | chenfon | 10 | 9,675 |
Some information for those who are about to restore their differential | krullibull | 0 | 3,305 |
06-06-2015 12:44 AM Last Post: krullibull |
trans oil, lsd oil change | Apolan | 9 | 17,309 |
Oil cooler -> low oil pressure | Jan Pedersen | 24 | 31,064 |
06-06-2013 07:36 PM Last Post: Deuce Cam |
