LSD oil friction modifier
02-18-2007, 11:28 AM
assassin,
in Holland here, you can get castrol, kroon and valvoline oils on every corner of the street, and loads of cheap unknown brands, but its hard to find specialist oils. The other day I went to 3 or 4 automotive shops (the ones that supply to local garages, not the DIY ones) asking for limited slip oils and they all went "you need what?!?"...
Dumb country Smile
Anyways, so far I've been using Valvoline GL5-LS oil for my stock diff but I can't judge on if its good or not... I'll go look for MOTUL because it does sound very interesting to see if it improves anythingSmile
02-18-2007, 02:58 PM
Mux213 Wrote:Anyways, so far I've been using Valvoline GL5-LS oil for my stock diff but I can't judge on if its good or not... I'll go look for MOTUL because it does sound very interesting to see if it improves anythingSmile
Sounds like it's a pain to get the higher end oils then. I don't know how much it'll help on a stock diff, unless you've rebuilt and it has good clutches - then go for it.
FYI: MOTUL makes awesome fluids & lubricants, It's somewhat hard to get at any normal automotive or race shop.
I get mine through a kawasaki dealer, they are EXTREMELY well known in the performance/race bike world. I think your best bet would be to call/shop around motorcycle race shops and see if they can order it up for you from their MOTUL distributor.
Andrew
02-18-2007, 03:50 PM
Andrew,
well I got a bad stock unit right now but as you can see a couple of posts down, I rebuild a diff a week or two ago thats almost ready to go in. We'll see how well we've done itBig Grin
  trans oil, lsd oil change Apolan 9 17,016 10-01-2014 03:57 PM
  Oil cooler -> low oil pressure Jan Pedersen 24 30,289 06-06-2013 07:36 PM
Last Post: Deuce Cam
  LSD Oil, Necessary? phill 92 6 8,290 04-06-2012 05:17 PM
Last Post: Sgonzalez
  4AGE crankcase gas and oil pressure too high, sprinking oil demogun 5 7,706 10-01-2011 09:47 AM
Last Post: demogun
  What's the LSD oil I should use? heshan 4 6,328 07-25-2011 08:13 PM
Last Post: heshan
