Oil Coolers
01-05-2005, 02:58 PM
Oil Coolers
The stock 4AGE oil cooler is the same as 4AF(E) and 3SGE one - just look at the salvage yards ! You can order the oil sender unit from Toyota dealer at ~30 EU brand new.
08-11-2007, 12:39 AM
Oil Coolers
Hi,
sorry, if my English is not perfect...
Today I wanted to replace the original oil cooler with a mocal unit, cause my rally car has after long stages a temperature of more than 140°C. I wanted to shortcut the original line, by just connecting the relief valve of the original adapter to the oil pan and use a sandwich plate, also by mocal, for the mainstream. But using this sandwich plate on the original adapter, I don´t have enough space for the oil filter, cause of the header. So my question is, if it is possible to fit the sandwich plate directly on the block and leave the adapter with the relief valve away? Or are there any reasons not to make it this way, for example to much pressure,etc.. I don´t know...
raki
08-11-2007, 10:01 AM
Oil Coolers
Indeed you must use only one adapter/sandwich plate.
08-11-2007, 11:09 AM
Oil Coolers
The 4AGE has a relief valve built into the oil pump to prevent the oil
pressure becoming too high during high rpm operation.
The factory oil cooler is a bypass type with its own relief valve. At low
rpm the oil cooler relief valve is closed, and no oil goes to the cooler.
At high rpm the oil flow increases, the pressure rises and the relief valve
opens. Excess oil flows thru the cooler and returns to the sump.
An after market full-flow oil cooler will be more effective. A new
sandwich plate that returns all the oil from the cooler to the engine will
be required. Remove the factory plate and block off the return to the sump.
A system that includes a thermostatic valve to restrict oil flow to the
cooler at low engine temperatures, would be nice Smile
Cheers... jondee86
08-11-2007, 12:11 PM
Oil Coolers
Quote:The 4AGE has a relief valve built into the oil pump to prevent the oil
So is the higher pressure a problem?
Most of the people I know built the aftermarket sandwich plate on the factory plate and just took a line from the factory plate to the oil pan, so they have a full-flow system and the relief valve, but it´s not possible with my exhaust system. So I need to know if I can just leave this relief valve away and put the aftermarket sandwich plate directly on the motor?
raki
http://www.sg-rallyesport.de
08-11-2007, 01:48 PM
Oil Coolers
I'm about to install a mocal thermostatic remote filter setup I got from Think Automotive. They were very good and extremely helpful. You can get some fancy rubber type aeroquip hose from them which does not need swaging and enables simple fitment at home.
The real cost comes with the various threaded fittings you require on top of the cost of the cooler and assorted adaptor plates.
I am fitting a straight out adaptor on the block with a remote filter mount installed just behind and low down to the battery tray with a home made alloy bracket to locate it. This remote filter mount then has a thermostatic plate attached to it. Then out to the setrab cooler.
Think automotive's website is extremely informative.
08-12-2007, 12:37 AM
Oil Coolers
@raki
In this country the AE86 was sold without an oil cooler. AFAIK the factory
cooler was only fitted to cars shipped to countries with hot summers Smile So
there is no problem in running the car without the factory bypass fitting.
@parrot
Makes good sense to mount the oil filter remotely if you are going to the
trouble of upgrading the cooler. They are not the easiest item to service
in the stock location !!!
I'm not certain why the factory installs a relief valve at the pump, but
would guess it is to protect the pump from excessive pressure/damage
when the oil is cold. The relief valve at the filter only opens at high rpm,
which is when the engine is working hard and generating more heat. A
simple way of only using the cooler when necessary.
Modified engines, stock engines used for racing, vehicles towing loads
or running in high ambient conditions, will all benefit from improved
cooling. In some cases this will include differential and transmission
coolers as well as oil coolers and larger radiators. Oil needs to be kept
within its design temperature/viscosity range to lubricate properly Smile
Cheers... jondee86
08-12-2007, 12:44 AM
Oil Coolers
Okay,
but without the factory plate, the pipe with the winding which is screwed in the block, doesn´t fit to fix the sandwichplate. It´s too long and I don´t find a way to fix it, except of cutting the pipe and making another winding, which is a problem.. Can I maybe use the pipe of a model without factory cooler?
raki
P.S.: So there are definately 2 relief valves? one in the pump in one in the factory bypass?
08-13-2007, 08:32 AM
Oil Coolers
If fitting oil cooler I would recommend using a thermostat
http://store.summitracing.com/partdetail...toview=sku
AE86 GTS '84 Red Top
08-13-2007, 01:54 PM
Oil Coolers
My sandwich plate has a thermostat, that´s not the prob.. Smile
  trans oil, lsd oil change Apolan 9 17,321 10-01-2014 03:57 PM
  Oil cooler -> low oil pressure Jan Pedersen 24 31,086 06-06-2013 07:36 PM
Last Post: Deuce Cam
  4AGE crankcase gas and oil pressure too high, sprinking oil demogun 5 7,931 10-01-2011 09:47 AM
Last Post: demogun
  Oil Presure and what oil i have to use? CHACAMAN 4 5,540 08-27-2008 05:35 AM
Last Post: F0Bman
  High engine oil temps - oil cooler discussion SutteR 28 23,824 06-08-2008 11:23 PM
Last Post: eight-six
