Oil Problem
08-25-2009, 05:29 PM
Oil Problem
Hi guys,
I did my 4AGE 96kw(3rd generation) over doing everything except the pistons. My head has been port&polished as well been gasflowed. I got an piggyback chip in as well. Problem is that when I drag through my gears ![]() I tried putting a breather filter on but still it leaks oil... ![]() How can I fix this problem? What do you guys thin could be wrong with my motor? ![]() |
trans oil, lsd oil change | Apolan | 9 | 17,595 |
Hot oil filter - a problem? | harkes | 5 | 6,764 |
01-03-2014 09:33 PM Last Post: Apsogos |
Oil cooler -> low oil pressure | Jan Pedersen | 24 | 31,767 |
4agZe problem solved - 99% IC problem | Okami | 41 | 37,611 |
07-12-2012 04:49 PM Last Post: Okami |
4AGE crankcase gas and oil pressure too high, sprinking oil | demogun | 5 | 8,108 |
