Oil Problem
08-25-2009, 05:29 PM
Oil Problem
Hi guys,
I did my 4AGE 96kw(3rd generation) over doing everything except the pistons. My head has been port&polished as well been gasflowed. I got an piggyback chip in as well.
Problem is that when I drag through my gears Cool at limit and I reached 3rd gear at about 6000rpm, then my oil push up so much that it goes into the breather pipe(on the cam cover) and straight to the manifold(Non TVIS) which in return I see black smoke coming out of my exhaust and I loose alot of power...
I tried putting a breather filter on but still it leaks oil... Banging head
How can I fix this problem? What do you guys thin could be wrong with my motor? Dumb question
  trans oil, lsd oil change Apolan 9 17,609 10-01-2014 03:57 PM
  Hot oil filter - a problem? harkes 5 6,775 01-03-2014 09:33 PM
Last Post: Apsogos
  Oil cooler -> low oil pressure Jan Pedersen 24 31,835 06-06-2013 07:36 PM
Last Post: Deuce Cam
  4agZe problem solved - 99% IC problem Okami 41 37,724 07-12-2012 04:49 PM
Last Post: Okami
  4AGE crankcase gas and oil pressure too high, sprinking oil demogun 5 8,121 10-01-2011 09:47 AM
Last Post: demogun
