Oil Problem
08-25-2009, 05:29 PM
Oil Problem
Hi guys,
I did my 4AGE 96kw(3rd generation) over doing everything except the pistons. My head has been port&polished as well been gasflowed. I got an piggyback chip in as well. Problem is that when I drag through my gears at limit and I reached 3rd gear at about 6000rpm, then my oil push up so much that it goes into the breather pipe(on the cam cover) and straight to the manifold(Non TVIS) which in return I see black smoke coming out of my exhaust and I loose alot of power... I tried putting a breather filter on but still it leaks oil... How can I fix this problem? What do you guys thin could be wrong with my motor? |
trans oil, lsd oil change | Apolan | 9 | 16,898 |
Hot oil filter - a problem? | harkes | 5 | 6,396 |
01-03-2014 09:33 PM Last Post: Apsogos |
Oil cooler -> low oil pressure | Jan Pedersen | 24 | 30,029 |
06-06-2013 07:36 PM Last Post: Deuce Cam |
4agZe problem solved - 99% IC problem | Okami | 41 | 35,467 |
4AGE crankcase gas and oil pressure too high, sprinking oil | demogun | 5 | 7,645 |
10-01-2011 09:47 AM Last Post: demogun |
