Oil leak
01-01-2008, 09:04 PM
Oil leak
Just had a good look around the car and I noticed a small engine oil leak, it appears to be coming from the bottom of the dipstick tube (4AGE 16v).
Does anyone know what seals the tube and how to remove it ?
Do I just pull it out ?
Thanks
01-01-2008, 10:12 PM
Oil leak
I had oil leak there, as well. My mechanic fixed it during oil change, but I'm not sure is he has put the new o-ring or something else. Maybe you should look in repair manual to be sure.
Fun is not the straight line!
01-02-2008, 10:45 AM
Oil leak
There is an o-ring on the tube so that could be it Smile
[Image: AEU86 AE86 - Oil leak]
01-02-2008, 03:05 PM
Oil leak
Yeps, just pull it out, fit on a new oring and put it back in.
01-02-2008, 04:48 PM
Oil leak
Oil leak? What oil leak, that puddle under the car is just sweat from all that horspower. Big Grin
01-02-2008, 07:25 PM
Oil leak
Thanks for all replies, I'll give it a go Thumbs up!
  trans oil, lsd oil change Apolan 9 17,099 10-01-2014 03:57 PM
  Oil leak (maybe a cylinder head gasket?) max_ae86 15 17,214 11-30-2013 03:59 AM
Last Post: jondee86
  Oil cooler -> low oil pressure Jan Pedersen 24 30,634 06-06-2013 07:36 PM
Last Post: Deuce Cam
  4AGE crankcase gas and oil pressure too high, sprinking oil demogun 5 7,814 10-01-2011 09:47 AM
Last Post: demogun
  T50 gearbox leak totta Crolla 3 6,006 05-28-2011 06:46 PM
Last Post: totta Crolla
