Oil leak
01-01-2008, 09:04 PM
Oil leak
Just had a good look around the car and I noticed a small engine oil leak, it appears to be coming from the bottom of the dipstick tube (4AGE 16v).
Does anyone know what seals the tube and how to remove it ? Do I just pull it out ? Thanks An analogue brain in a digital World |
01-01-2008, 10:12 PM
Oil leak
I had oil leak there, as well. My mechanic fixed it during oil change, but I'm not sure is he has put the new o-ring or something else. Maybe you should look in repair manual to be sure.
Fun is not the straight line! |
01-02-2008, 10:45 AM
Oil leak
There is an o-ring on the tube so that could be it
Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
01-02-2008, 03:05 PM
Oil leak
Yeps, just pull it out, fit on a new oring and put it back in.
01-02-2008, 04:48 PM
Oil leak
Oil leak? What oil leak, that puddle under the car is just sweat from all that horspower.
01-02-2008, 07:25 PM
Oil leak
Thanks for all replies, I'll give it a go
trans oil, lsd oil change | Apolan | 9 | 17,099 |
Oil leak (maybe a cylinder head gasket?) | max_ae86 | 15 | 17,214 |
11-30-2013 03:59 AM Last Post: jondee86 |
Oil cooler -> low oil pressure | Jan Pedersen | 24 | 30,634 |
4AGE crankcase gas and oil pressure too high, sprinking oil | demogun | 5 | 7,814 |
T50 gearbox leak | totta Crolla | 3 | 6,006 |
05-28-2011 06:46 PM Last Post: totta Crolla |
User(s) browsing this thread: 12 Guest(s)
