TPS and stop screw set up
04-22-2017, 09:30 PM
Anyone have a link on how to set the TPS and stop screw?
Car hunts something stupid but the TPS set up I've followed hasn't seemed to work. |
04-22-2017, 10:38 PM
It's very late here so for now just a short answer: You can find the proper adjustment in the manual available in tech section. I'll add more tomorrow if needed.
AE86 ex-daily |
04-22-2017, 10:44 PM
You can find it on page 145 of the 4A-GE manual:
http://files.aeu86.org/manuals/4A-GEManual.pdf 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
04-22-2017, 10:52 PM
Then look for information on how to check and clean/replace the
thermostatic idle-up valve under the throttle body. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
04-23-2017, 12:28 PM
Thanks for the replies
Jondee, I've had a look at the thermostatic idle-up cleaning but am I wrong in saying that the idle up is just for AC and power steering on the underside of the throttle body? |
04-23-2017, 01:15 PM
The A/C idle-up uses a separate solenoid valve to let air into the
downstream side of the AAV. The P/S idle-up is a mechanical valve that allows air from the upstream side of the AAV to pass into the downstream side. Neither of them are affected by the operation of the AAV itself. The AAV is contolled by a wax filled capsule that is heated by the circulating coolant so that it gradually expands and cuts off the extra air by-passing the throttle butterfly. It is very common for the AAV (or the two little water hoses) to get blocked. If the idle goes high and stays high as the engine warms up, at a certain temperature it will start to cycle on fuel cut. The effect is a rise in fall in revs that sound like you are gently pressing and releasing the gas pedal. Here is some information on how to clean the valve if it is blocked... http://club4ag.com/forums/viewtopic.php?t=12013 When the engine is warmed up, both of the little water hoses should get hot. If one gets a bit warm but the other one stays cool, the valve or hoses are blocked and the valve will not close to bring your idle down as the engine warms up. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
04-23-2017, 01:22 PM
What Jondee is referencing to is the waxstat under the throttle body, that has the two small water line hoses connected too. You can remove, and try cleaning the waxstat with carb cleaner. If you go that far, I would remove the complete TB and clean everything. The problem could also be an air-lock in the cooling system if the coolant has been drained. If you do adjust the waxstat, it does not take a lot to reduce the RPM. I my case .5mm adjustment reduce the RPM by about 400 to 500 RPM while cold. Dave W
04-23-2017, 09:40 PM
(This post was last modified: 04-23-2017 09:41 PM by kazi.)
(04-23-2017 01:22 PM)Dave W Wrote: What Jondee is referencing to is the waxstat under the throttle body, that has the two small water line hoses connected too. You can remove, and try cleaning the waxstat with carb cleaner. If you go that far, I would remove the complete TB and clean everything. The problem could also be an air-lock in the cooling system if the coolant has been drained. If you do adjust the waxstat, it does not take a lot to reduce the RPM. I my case .5mm adjustment reduce the RPM by about 400 to 500 RPM while cold. Dave W AH! now i never thought about a coolant airlock. i did have to drain the system after the timing belt tensioner snapped to change the belt. i might try bleeding the system first before i do anything else. its only started doing this since the belt change. either that or I've set the TPS up completely wrong. failing that i might change over the throttle body to my old one as i know that one is fiona and set up well. (04-23-2017 01:15 PM)jondee86 Wrote: The A/C idle-up uses a separate solenoid valve to let air into the thanks for the always detailed response dude |
Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE | Homem Bomba | 3 | 11,086 |
10-25-2013 05:13 PM Last Post: Apsogos |
TPS for carbs | totta Crolla | 7 | 7,580 |
01-30-2013 09:14 PM Last Post: totta Crolla |
tps codes | totta Crolla | 1 | 4,027 |
08-01-2010 03:05 PM Last Post: totta Crolla |
TPS 89452-12090 | gjuro | 2 | 5,277 |
05-12-2010 12:41 AM Last Post: isac |
16v to 20v throttle body's TPS | lolali | 4 | 9,243 |
10-21-2009 01:04 PM Last Post: isac |
